6 Replies Latest reply on Jun 1, 2009 3:35 AM by *Prashant Shelke*
    which data type is there in flex to insert clob data in the database
    sweetysk
      Hello,
              To insert routepath of the map I have declared one variable in the flex application and I am inserting that variable in database i.e.,I am inserting clob data type. I have to return clob data from flex application to java code. so that I can insert clob data in database.
      Is there any datatype in flex which is equivalent datatype as clob?
      Can anyone help me?
      Thanks in Advance.
        • 2. Re: which data type is there in flex to insert clob data in the database
          varun rathore Level 1
          Basically there is no specific data type in flex to insert Blob , you can though use * type of variable as follows
          var clobType : * ;
          now this type of variable will accept data of any type
          You can seralize it on server end and save it in Blob type and then while retriving you can deseriale it and send it back to flex.
          Cheers
          Varun Rathore
          http://www.vrathore.blogspot.com
          • 3. Re: which data type is there in flex to insert clob data in the database
            sweetysk Level 1
            I am getting the below error.
            code:
            Server.ResourceUnavailable
            Message:
            Cannot invoke method 'storeDirection'.
            Detail:
            The expected argument types are (java.sql.Clob) but the supplied types were (java.lang.String) and converted to (null).
            Please find the attached file for the mxml code.
            And this is the code written in java class
            public
            void
            storeDirection(java.sql.Clob direction){
            getConnection();
            try
            query = "insert into testemp values(?)";
            pstmt = con.prepareStatement(query.toString());
            pstmt.setClob(1,direction);
            pstmt.executeUpdate();
            catch
            (Exception e){
            e.printStackTrace();
            finally
            try
            if(con != null
            con.close();
            if(pstmt != null
            pstmt.close();
            catch
            (SQLException e){
            e.
            printStackTrace();
            Can anyone please help me?
            • 4. Re: which data type is there in flex to insert clob data in the database
              sweetysk Level 1
              code:
              Message:
              Detail:
              The code snippets are..
              <mx:Application
              xmlns:mx="http://www.adobe.com/2006/mxml" width="100%" height="100%" viewSourceURL="srcview/index.html"
              <mx:RemoteObject
              id="emp" fault="faultHandler(event)" showBusyCursor="true" destination="FlexDb"
              <mx:method name="storeDirection" result="resultHandler(event)"
              </mx:RemoteObject>
              <mx:Panel backgroundColor="#FFFFFF" width="100%" height="100%" paddingLeft="5" paddingTop="5"
              <mx:VBox width="100%" height="100%"
              <mx:HBox width="100%"
              <mx:TextInput id="from" text="600 N Lamar Blvd, Austin, TX" width="200"
              <mx:Label text=" to "
              <mx:TextInput id="to" text="320 E 6th St, Austin, TX" width="200"
              <mx:Button id="submitButton" label="Go" click="processForm(event);"
              </mx:HBox>
              <mx:UIComponent id="mapHolder" initialize="onHolderCreated(event);" resize="onHolderResized(event)" width="100%" height="100%"
              <mx:Text id="description" text="" width="100%" textAlign="center" fontSize="18" height="40"
              </mx:VBox>
              </mx:Panel>
              <mx:Script>
              <![CDATA[
              import
              mx.rpc.events.ResultEvent;
              import
              mx.rpc.events.FaultEvent;
              import
              com.google.maps.InfoWindowOptions;
              import
              com.google.maps.LatLng;
              import
              com.google.maps.LatLngBounds;
              import
              com.google.maps.Map;
              import
              com.google.maps.MapEvent;
              import
              com.google.maps.MapMoveEvent;
              import
              com.google.maps.overlays.Marker;
              import
              com.google.maps.overlays.MarkerOptions;
              import
              com.google.maps.interfaces.IPolyline;
              import
              com.google.maps.services.*;
              import
              flash.display.Loader;
              import
              flash.display.MovieClip;
              import
              flash.net.URLRequest;
              import
              mx.controls.Alert;
              private var
              map:Map;
              private var
              dir:Directions;
              private var
              steps:Array;
              private var
              stepIndex:uint;
              private var
              polyline:IPolyline;
              private function resultHandler(evt:ResultEvent):void
              description.text = evt.message.toString();
              private function faultHandler(fault:FaultEvent):void
              Alert.show(
              "code:\n" + fault.fault.faultCode + "\n\nMessage:\n" + fault.fault.faultString + "\n\nDetail:\n"
              + fault.fault.faultDetail);
              public function onHolderCreated(event:Event):void
              this.map = new
              Map;
              this.map.key = "ABQIAAAAKLe0_mKipf1gsfnpmrQigRT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQ8RzJwVkCiFn9GUTtAjx6u8l92vA"
              this
              .map.addEventListener(MapEvent.MAP_READY, onMapReady);
              mapHolder.addChild(map);
              private function onMapReady(event:Event):void
              dir =
              new
              Directions();
              dir.addEventListener(DirectionsEvent.DIRECTIONS_SUCCESS, onDirLoad);
              private function processForm(event:Event):void
              dir.load(
              "from: " + from.text + " to: " + to
              .text);
              private function onDirLoad(event:DirectionsEvent):void
              var
              dir:Directions = event.directions;
              var
              startLatLng:LatLng = dir.getRoute(0).getStep(0).latLng;
              var
              endLatLng:LatLng = dir.getRoute(dir.numRoutes-1).endLatLng;
              polyline = dir.createPolyline();
              map.clearOverlays();
              map.addOverlay(polyline);
              map.addOverlay(
              new
              Marker(startLatLng));
              map.addOverlay(
              new
              Marker(endLatLng));
              map.setCenter(dir.bounds.getCenter(), map.getBoundsZoomLevel(dir.bounds));
              steps = [];
              stepIndex = 0;
              setControls(
              false
              var msg:*;
              for (var r:int = 0; r < dir.numRoutes; r++) {
              var route:Route = dir.getRoute(r);
              for (var s:int = 0; s < route.numSteps; s++) {
              var step:Step = route.getStep(s);
              steps.push({
              start: step.latLng,
              index: step.polylineIndex,
              description: step.descriptionHtml +
              " (" + step.distanceHtml + ", "
              step.durationHtml +
              msg = msg+ step.descriptionHtml +
              " (" + step.distanceHtml + ", " +step.durationHtml + ")\n"
              Alert.show(msg);
              emp.storeDirection.send(msg);
              private function setControls(on:Boolean):void
              from.enabled = on;
              to
              .enabled = on;
              submitButton.enabled = on;
              public function onHolderResized(event:Event):void
              this.map.setSize(new
              Point(mapHolder.width, mapHolder.height));
              </mx:Script>
              </mx:Application>
              and coming to java code
              public
              void
              getConnection();
              try
              catch
              (Exception e){
              finally
              try
              if(con != null
              con
              .close();
              if(pstmt != null
              pstmt
              .close();
              catch
              (SQLException e){
              • 5. Re: which data type is there in flex to insert clob data in the database
                *Prashant Shelke* Level 4
                I think there is problem from where you are calling setDirection(Clob), while calling ensure you done casting properly.
                Thanks.
                • 6. Re: which data type is there in flex to insert clob data in the database
                  I think data which you are sending from Actionscript(of type * ) is getting converted to String type so thats why its giving exceptions.
                  So try to cast to Clob/ Blob in JAVA.
                  referr
                  http://www.artima.com/forums/flat.jsp?forum=1&thread=22568&start=0
                  http://forums.sun.com/thread.jspa?threadID=349880&start=15
                  Thanks.
