0 Replies Latest reply on Jun 1, 2009 3:07 AM by Mr Bounce
    duplicate method (CS2 and CS3)
    Mr Bounce
      I asked a question about duplicating images from one document to another that didn't exist on the local drive anymore.
      I tried someones suggestion to duplicate the box containing the image, to the other document, then setting the new box's properties to match the target box and deleting the target box.
      That method works great with CS3 but the same code does not work with CS2 - just wanted to post my method to see if anyone could see why....
      (Before running this l've opened two documents with a rectangle labeled 'pic1' on both - l've only placed an image in doc 1's box)
      property myDocuments : {}
      set boxName to "pic1"
      tell application "Adobe InDesign CS3"
      -- tell application "Adobe InDesign CS2"
            -- Source
            tell active document
                  set MyRectangles to page item boxName
                  set MyRectangle to item 1 of MyRectangles
                  set thePage to parent of MyRectangle
                  set thePageNumber to name of thePage
            end tell
            if (count documents) = 0 then
                  display dialog "Please, open a document" buttons "OK" default button 1 with icon caution
            else
                  repeat with d from 1 to count documents
                        set MyDocument to document d
                        set end of myDocuments to MyDocument
                  end repeat
            end if
            set docCount to the number of items in myDocuments
            repeat with x from 2 to docCount
                  set proceed to true
                  set myPasteDocument to (item x of myDocuments)
                  tell myPasteDocument
                        -- Target
                        set MyTargetRectangles to page item boxName
                        set MyTargetRectangle to item 1 of MyTargetRectangles
                        set theTargetPage to parent of MyTargetRectangle
                        set theTargetPageNumber to name of theTargetPage
                        set {y, x, l, h} to geometric bounds of MyTargetRectangle
                        -- LINE ONLY WORKS IN CS3 not CS2
                        set MyTargetRectangleCopy to duplicate MyRectangle to page theTargetPageNumber
                        -- DELETES FROM DOC2- CS3 and CS2 - OK
                        delete MyTargetRectangle
                        -- MOVE AND SET MOVES DUPLICATE ITEM on DOC1 - SHOULD BE ON DOC2
                        move MyTargetRectangleCopy to {x, y}
                        set geometric bounds of MyTargetRectangleCopy to {y, x, l, h}
                  end tell
            end repeat
      end tell
      Regards, Gary.
