4 Replies Latest reply on Aug 24, 2009 6:58 AM by pkatpadi
    How to add a Hyperlink to open popup in dynamic data grid?
    himanshuFlex
      I am a new bie in FLEX, the question which I am asking might be very easy but i am not able to find solution to it. Please can some one help me.
      I am creating a data grid dynamically using action script code now I want to add a Hyper link to couple of columns in a row. How can I do it in FLex?
      Thanks.
        • 1. Re: How to add a Hyperlink to open popup in dynamic data grid?
          *Prashant Shelke* Level 4
          Please see following code.
          Loop on dataGrid column array
                    if(dataGrid.columns[cnt].dataField == "dataField") // here you can make choice for which column u want link.
                               var classFacory:ClassFactory = new ClassFactory(LinkRenderer); // here LinkRenderer is any mxml/ as file Having Link Button defined.
                              dataGrid.columns[cnt].itemRenderer = classFacory;
          Hope this will work for u.
          Thanks.
          • 2. Re: How to add a Hyperlink to open popup in dynamic data grid?
            himanshuFlex Level 1
            HI Prashant,
            Thanks for the reply.
            This is what I am currently doing right now:
            for
            (var
            i:int=0; i<colNameList.length;i++) {
            var headerText:String = colNameList[i] + ""
            callSellGridCol = cols[i];
            callSellGridCol.headerText = headerText;
            if(headerText != null && headerText == "RIC"
            var myRenderer : ClassFactory = new
            ClassFactory(com.db.carving.synthetic.dma.view.UrlLinkRenderer);
            In My Renderer class :
            public
            class UrlLinkRenderer extends LinkButton
            public var clickFunction:Function;
            public function UrlLinkRenderer() {
            super();
            // Override the set method for the data property.
            override public function set data(value:Object):void
            super.data = value;
            if (value != null)
            label = value[DataGridListData(listData).dataField];
            else
            label =
            super.invalidateDisplayList();
            Now what i want is to add a new Event Listner to this object so that I can click it?
            Where should be the Link button defined??
            Thanks.
            • 3. Re: How to add a Hyperlink to open popup in dynamic data grid?
              see following code,
              callSellGridCol.itemRenderer = myRendere;// Your Link button code is in actionscript!
              & in constructor
              super();
              this.addEventListener(MouseEvent.CLICK,onClickLinkButton);
              public function onClickLinkButton(event:MouseEvent)
                your code will go here...
              Hope this will help u.
              • 4. Re: How to add a Hyperlink to open popup in dynamic data grid?
                pkatpadi
                Hi I was looking at one of your solutions and I have a problem which is closely associated to your post. I was wondering if you had any thoughts.
                http://forums.adobe.com/thread/481756?tstart=0
