3 Replies Latest reply on Jun 1, 2009 5:59 AM by iggyotis
    cant unload movies on two different levels?
    iggyotis
      Hi guys,
      I am having trouble with unload an loading movies. Basically I am loading a movie into a container, which works a charm:
      graphicsbut.onRelease = function() {
      _root.createEmptyMovieClip("container",1);
      loadMovie("Graphics/Graphics.swf","container");
      container._x = -22 ;
      container._y = 0 ;
      And then I want to load another movie above this one, also working:
      Dyson_hit.onRelease = function()
      Dyson_mc.gotoAndPlay("out");
      loadMovieNum("Graphics/Catwalks.swf", 2);
      disableBtns();
      But NOW the problem....I want to unload them both when a close button is pressed on the third loaded swf?
      Also, ideally I would like to add that second movie clip into a container, so I can position it correctly, but when I try copying the code I use on the first, it doesn't seem to work...is it to do with the "root" bit perhaps?
        • 1. Re: cant unload movies on two different levels?
          iggyotis Level 1
          ahh I did it with this code:
          on (release) {
                _root.container.unloadMovie()
                unloadMovieNum(2);
                _level0.enableBtns();
          I would still like to load the second swf into a container so if anyone can tell me how to do that, that would be great:-)
          • 2. Re: cant unload movies on two different levels?
            iggyotis Level 1
            ok, I seem to be able to load the next movie into a container with this:
            Elnett_hit.onRelease = function() {
                loadMovie("Advertorial/Elnett/Elnett.swf","container");
                container._y = 0 ;
            • 3. Re: cant unload movies on two different levels?
              to load both into a container movieclip:
              container._y = 0 ;
              _root.createEmptyMovieClip("container2",2);  // use higher depth and different name
              loadMovie("Graphics/Catwalks.swf", _root.container2);
              disableBtns();
              and you can control movieclips loaded into _levels:  you must wait until loading is complete (ie, use preloader code or an mcl).
