1 Reply Latest reply on Jun 1, 2009 8:19 AM by Gaurav J
    not work for Alert window on Locale
    master.card
      I try to support my web sire with Locale, it work fine with title, text and label.
      like
      <mx:Label
      verticalCenter="middle" text="{resourceManager.getString('lang', 'comm.operations')}:" fontWeight="bold" />
      But it does not work in the popup Alert window.
      Alert.show(
      "{resourceManager.getString('lang', 'login.salt.msg')}");
      May I know how to support it?
      thanks
        • 1. Re: not work for Alert window on Locale
          Gaurav J Adobe Employee
          You are probably calling the Alert.show() from the <mx:Script> block. The Script block is for actionscript code, but the curly braces binding sytax is for mxml.
          You can create the binding for resourceManager.getString('lang', 'login.salt.msg') to a variable using <mx:Binding> and then use that variable in the call to Alert.show().
          HTH,
          Gaurav Jain
          Flex SDK Team
