0 Replies Latest reply on Jun 1, 2009 9:34 AM by Peter Farland
    [svn:fx-trunk] 7467: Removing font face validation so that the requested style is used whether or not it matches what the font describes .
    Peter Farland Level 3
      Revision: 7467
      Author:   pfarland@adobe.com
      Date:     2009-06-01 08:10:15 -0700 (Mon, 01 Jun 2009)
      Log Message:
      Removing font face validation so that the requested style is used whether or not it matches what the font describes. This allows font families to be constructed from multiple fonts including those that do not describe their style in the OS/2 table. Note SWF and the Flash Player restriction of only support 4 faces per font family (plain, bold, italic, and bold & italic) still applies.
      QE: Yes, please look out for negative test cases for embedded font styles that no longer fail. Also look out for minor font outline differences given that we use AFEFontManager by default for DefineFont3 embedded fonts. If you require the legacy font outlines you can configure the test case to use the BatikFontManager (which has been retained for MPL distributions).
      Doc: Yes, we'll release note the relaxed font embedding rules for font faces. I'll annotate the bugs below.
      Reviewer: Paul
      Bugs:
      SDK-14309 - fontWeight should not be restricted
      SDK-14308 - fontWeight: bold is required when specifying certain fonts in the CSS file
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-14309
          http://bugs.adobe.com/jira/browse/SDK-14308
      Modified Paths:
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/lib/flex-fontkit.jar
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/common/MxmlConfiguration.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/BatikFontManager.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/CachedFontManager.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/FontManager.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/fonts/JREFontManager.java
