1 Reply Latest reply on Jun 1, 2009 8:49 PM by mentlity
    if statement question
    mentlity Level 1
      I need to find out how to code this correctly
      from the main timeline in level 0, if you load (1.swf ) in level 1
      I need  (button1) on the main timeline  to be hidden and not function while the swf in level 1 is playing. (will a button hidden still show the cursor?)
      If (1. swf) in level 1 is NOT playing than (button1) should be visible and working.
      Or I can just change the button to an mc and when the (1.swf plays) in level 1 the (mc1) should be removed
      if (1. swf) in level 1 is NOT playing than  (mc1) should be visible and functioning.
      Still grasping the if statement and I believe this can be used here but I need help on how to code it
        • 1. Re: if statement question
          you'll either need to use a loop to repeatedly check if _level1 exists and, if it is, determine if its timeline is playing or use some specifics of your setup to obviate the need for the loop.
          to make a button (mc1) visible (and functioning) or not visible (and not functioning) you can use:
          mc1._visible = false;  // or true
          you can also assign its _alpha property to make it visible or not but it will always be functioning, even when not visible, if you use the _alpha property.  so, it would much more typical to use the _visible property.
