23 Replies Latest reply on Dec 9, 2009 8:14 PM by poyeehamwang
      • 2. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
        jeremy.anderson Level 1
        I get a similar error on Mac OSX.  I've tried uninstalling/reinstalling even rebooting (which I haven't had to do on my Mac in ages :-O)...still no worky.
        • 3. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
          dhoopingarner Level 1
          That reminds me of a problem I had with an earlier version of Flash (MX?) when it first came out five or six years ago. The problem was caused by moving from one network to another (in my case, between a wired network at the office and a wireless network at home). If memory serves, Macromedia had to issue a fix for it. Hope this helps to shed light on the problem, wish I could help more.
          • 4. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
            olive009 Level 1
            but after several times reinstall,still can't launch
            • 5. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
              Larry McLister (Adobe) Adobe Employee
              Hi There,
              Please try the steps below.  If you are still seeing problems, please take a look at KB405970.  Please post back and let everyone know how it goes.
              Also, there are some other good bits of information in the Flash Builder Release notes.
              -Larry
              If Flash Builder Beta fails to launch successfully after installation, or if you receive a Licensing error message during launch, here's the recommended workaround:
              1. Quit all running applications.
              2. Uninstall Flash Builder Beta.
              3. Making sure that there are still no other applications running, install Flash Builder Beta.
              4. In most cases, steps 1-3 should be enough, but if it still won't launch, a reboot can help as a follow-up.
              • 6. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                I've already tried those steps numerous times to no avail.
                I'll look into the KB article next I suppose.
                • 7. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                  deepa subramaniam (adobe) Level 2
                  Please try out the KB article and check out the FlashBuilder release notes, as Larry mentions. If it works, please specify what fixed the issue, and if it doesn't work, specific information about what you tried will be helpful in diagnosing the problem. Replying back to this thread is the best route and I'll work with you to get your install issues figured out!
                  • 8. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                    For anyone who hasn’t been able to launch Flash Catalyst successfully, try these steps in this exact order:
                    1)      launch Catalyst and verify you get the "license expired" error (this helps make sure we’re all at the same starting point)
                    2)       uninstall Catalyst
                    3)       reboot
                    4)       without opening any other programs, run the license repair tool.
                    a.       There are 3 possible places in the repair tool dialog where you can enter options. Follow these exactly:
        i.      When asked about language, press "e" (without the quotes )
        ii.      When asked if you want to shut down any programs, press "n"
        iii.      when asked if you are ready to run the repair, press "0"
                    NOTE: the terminal will appear as follows at this step:
                    ** If you are ready to run the repair, then press
                    the "enter/return" key now.
                    ** If you have already run the repair once, but it didn’t work,
                    then reboot and run the repair again (files may have been locked).
                    ** If you have run the repair after rebooting and it still didn’t
                    work, then reboot and when you get to this screen, enter 0.
                    (If the steps above did not work, and licensing continues to fail,
                    then please contact customer support.)
                    Note: This may take a few moments.
                    5)       Re-install Catalyst and use the serial number posted on the pre-release site
                    6)       Launch Catalyst
                    At this point you should be set. If not, please let us know.
                    We are working on resolving the licensing issue for Flash Builder.
                    • 9. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                      C. Agruss (Adobe) Level 3
                      For any of you who've experience Licensing errors, please take a look in your temp folder, and see if you can locate the files named "amt.log" and "alm.log". If so, please attach your logs to this forum thread for diagnosis.
                      -Chris
                      • 10. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                        olive009 Level 1
                        OHG,your way didn't work.and I got this when I launch the repaire tool
                        • 11. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                          Hello -
                          So you're sure you're running the repair tool to help with your Flash Catalyst installation, correct? Additionally, you didn't delete anything manually?
                          As for the error when running the repair tool, one observation is that at the top of that posted screen shot, you have double byte characters in the path. The repair instructions provided were to run it in English. I'm not too familiar with the specifics of the repair tool, but can you try running it in Japanese as well?
                          Deepa Subramaniam
                          Flex SDK Engineer
                          • 12. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                            CSpiewok Level 1
                            here Flash Builder Beta is not working either. This is the relevant part of the "alm.log" - file:
                            2009-06-03 09:02:27 [1340] ALM: _info_: ==========================================
                            2009-06-03 09:02:27 [1340] ALM: _info_: Start ALM 3.0 Release (build 3.0.11.10077)
                            2009-06-03 09:02:27 [1340] ALM: _info_: Host app is Licensable App
                            2009-06-03 09:02:27 [1340] ALM: _info_: Found LEID FlexBuilder-CS4-Win-PR with AMT Path C:\Program Files\Adobe\Flash Builder Beta\AMT
                            2009-06-03 09:02:27 [1340] ALM: _info_: MediaTagPolicy is RET
                            2009-06-03 09:02:27 [1340] ALM: _info_: Canonical LEID is FlexBuilder-CS4-Win-PR
                            2009-06-03 09:02:27 [1340] ALM: _info_: Driver LEID is FlexBuilder-CS4-Win-PR
                            2009-06-03 09:02:27 [1340] ALM: _info_: Loading adobeconfig (version = 2.5) for LEID FlexBuilder-CS4-Win-PR
                            2009-06-03 09:02:27 [1340] ALM: _time_: (func: ALM_Initialize, duration: 0.015 sec)
                            2009-06-03 09:02:27 [1340] ALM: _info_: Validate license at Pre-Chrome time
                            2009-06-03 09:02:27 [1340] ALM: _info_: Searching license for locale en_US ...
                            2009-06-03 09:02:27 [1340] ALM: _info_: Found no existing serialization
                            2009-06-03 09:02:27 [1340] ALM: _info_: Searching serial number for all possible LEIDs ...
                            2009-06-03 09:02:27 [1340] ALM: _info_: Found no serial number
                            2009-06-03 09:02:27 [1340] ALM: _info_: This is the most preferred locale, check trial license
                            2009-06-03 09:02:27 [1340] ALM: _info_: Scan trusted storage
                            2009-06-03 09:02:28 [1340] ALM: __req_: (func: adobe::alm::ALM_TrustStorage_Scan, line: 383)
                            2009-06-03 09:02:28 [1340] ALM: _info_: Failed to scan trusted storage: 148 : 3
                            2009-06-03 09:02:28 [1340] ALM: _info_: Current license status is Invalid, license type is None (P=0x00, S=0x00, R=-1)
                            2009-06-03 09:02:28 [1340] ALM: _time_: (func: ALM_License_SilentValidate, duration: 0.234 sec)
                            2009-06-03 09:02:28 [1340] ALM: _info_: ALM_License_SilentValidate return license status: Invalid and error: 148 : 3
                            And this is from the amt.log:
                            2009-06-03 10:03:12 [1544]  AMT: START SESSION, library version 2.0.1.10077,53.352460
                            2009-06-03 10:03:12 [1544]  AMT: Initializing C:\Program Files\Adobe\Flash Builder Beta\
                            2009-06-03 10:03:12 [1544]  AMT: Adobe License Manager version 3.0 (build 11.10077) RELEASE
                            2009-06-03 10:03:12 [1544]  PCDService: PCD Service in threaded mode
                            2009-06-03 10:03:12 [1544]  performance: AMTPreObtainProductLicense took 3.076927 ms
                            2009-06-03 10:03:12 [1544]  PCD thread: PCD thread started
                            2009-06-03 10:03:12 [1544]  AMT: App Product Locale [0] = en_US
                            2009-06-03 10:03:12 [1544]  config: Loading configuration for C:\Program Files\Adobe\Flash Builder Beta\AMT\application.xml
                            2009-06-03 10:03:12 [1544]  config: Found default (non-installed) payload code FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  config: Failed to find install-time driver payload; payload acts as its own driver
                            2009-06-03 10:03:12 [1544]  config: Falling back to file-based license configuration
                            2009-06-03 10:03:12 [1544]  config: Setting current license to the driver at startup because no mapping was found.
                            2009-06-03 10:03:12 [1544]  config: Setting current license to FlexBuilder-CS4-Win-PR [ALL]
                            2009-06-03 10:03:12 [1544]  config: payload code: FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  config: driver payload code: FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  config: driver licensing code: FlexBuilder-CS4-Win-PR
                            2009-06-03 10:03:12 [1544]  config: current licensing code: FlexBuilder-CS4-Win-PR
                            2009-06-03 10:03:12 [1544]  config: current locale code: ALL
                            2009-06-03 10:03:12 [1544]  config: Done loading configuration
                            2009-06-03 10:03:12 [1544]  config: Setting insalled locales
                            2009-06-03 10:03:12 [1544]  config: Changing locale to "en_US" because old locale "" is not in the new list of installed languages
                            2009-06-03 10:03:12 [1544]  AMT: config: Finding license info for payload: FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  AMT: config: PayloadCode: FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  AMT: config: Driver PayloadCode: FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  AMT: config: Installed LicensingCode: FlexBuilder-CS4-Win-PR
                            2009-06-03 10:03:12 [1544]  AMT: config: Registration is suppressed.
                            2009-06-03 10:03:12 [1544]  AMT: config: Updates are suppressed.
                            2009-06-03 10:03:12 [1544]  AMT: config: No BridgeTalkCode found in configuration; Bridgetalk will be disabled.
                            2009-06-03 10:03:12 [1544]  AMT: Application is serialized.
                            2009-06-03 10:03:12 [1544]  AMT: First launch (serial [92750706223402418935]).
                            2009-06-03 10:03:12 [1544]  AMT: Application state initialized.  Obtaining Product License.
                            2009-06-03 10:03:12 [1544]  AMT: Obtaining client features from cache.
                            2009-06-03 10:03:12 [1544]  AMT: Obtaining client product info from cache.
                            2009-06-03 10:03:12 [1544]  AMT: Forcing first launch workflow because product is not licensed from previous launch.
                            2009-06-03 10:03:12 [1544]  AMT: AMT: Obtaining Product License.
                            2009-06-03 10:03:12 [1544]  AMT: Launch Workflow not yet done in foreground in this session.
                            2009-06-03 10:03:12 [1544]  AMT: Starting First Launch Workflow
                            2009-06-03 10:03:12 [1544]  config: No media tag found for payload FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:12 [1544]  config: Using default media policy RET
                            2009-06-03 10:03:12 [1544]  AMT: Suppressing EULA display on requst
                            2009-06-03 10:03:12 [1544]  AMT: Starting ALM workflow.
                            2009-06-03 10:03:12 [1544]  AMT: Initializing ALM for serialized activation.
                            2009-06-03 10:03:12 [1544]  ALMService: Initializing as licensed app
                            2009-06-03 10:03:12 [1544]  ALMService: Setting FNP path to C:\Program Files\Adobe\Flash Builder Beta\plugins\com.adobe.flexide.amt_4.0.0.235740\os\win32\x86
                            2009-06-03 10:03:12 [1544]  ServiceLoader: Removing reference to library adobelm.dll
                            2009-06-03 10:03:12 [1544]  ServiceLoader: Unloading library adobelm.dll
                            2009-06-03 10:03:12 [1544]  AMT: Performing ALM silent license verification.
                            2009-06-03 10:03:13 [1544]  config: Setting current license to FlexBuilder-CS4-Win-PR [ALL]
                            2009-06-03 10:03:13 [1544]  ALMService: License_Check error 148:3. (Errno = 2)
                            2009-06-03 10:03:13 [1544]  AMT: ALM failed to initialize and read trusted storage, hence no license.
                            2009-06-03 10:03:13 [1544]  AMT: Starting Data Collection for SWTag_Init()
                            2009-06-03 10:03:13 [1544]  AMT: DoISOTagging() productCanonicalLEID = FlexBuilder-CS4-Win-PR;outMappedLEID =  FlexBuilder-CS4-Win-PR, unused =  Þ¨89iÿþþÿÿÿáX¨8c
                            2009-06-03 10:03:13 [1544]  AMT: DoISOTagging() productPayloadCode = FlexBuilder-Installer-AdobeCode;driverPayloadCode =  FlexBuilder-Installer-AdobeCode
                            2009-06-03 10:03:13 [1544]  AMT: SWTag_Init() Tags Arguments Flash Builder; FlexBuilder-CS4-Win-PR;
                            2009-06-03 10:03:13 [1544]  AMT: DoISOTagging() License Status = unlicensed
                            2009-06-03 10:03:13 [1544]  AMT: DoISOTagging() Tags 927507062234024189359556; 4.0; TRIAL
                            2009-06-03 10:03:13 [1544]  AMT: DoISOTagging() Product Version 4; 0
                            2009-06-03 10:03:13 [1544]  performance: AMTObtainProductLicense took 374.653748 ms
                            2009-06-03 10:03:14 [1544]  AMT: Pre-Validating Product License.
                            2009-06-03 10:03:14 [1544]  AMT: Services already loaded in this session.
                            2009-06-03 10:03:14 [1544]  performance: AMTPreValidateProductLicense took 0.130464 ms
                            2009-06-03 10:03:14 [1544]  AMT: AMT: Validating Product License.
                            2009-06-03 10:03:14 [1544]  AMT: Launch Workflow already done in this session.
                            2009-06-03 10:03:14 [1544]  AMT: Checking client features against cache.
                            2009-06-03 10:03:14 [1544]  AMT: Silent licensing failure during feature checks, hence no license.
                            2009-06-03 10:03:14 [1544]  AMT: Validating client product info against cache.
                            2009-06-03 10:03:14 [1544]  AMT: Product is unlicensed.
                            2009-06-03 10:03:14 [1544]  AMT: DoISOTagging() called more than once for the same license state! Old State = 0, New State = 0
                            2009-06-03 10:03:14 [1544]  AMT: Failure Validating Product License!
                            2009-06-03 10:03:14 [1544]  performance: AMTValidateProductLicense took 35.272568 ms
                            Best regards,
                            Christian
                            • 13. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                              Hi Christian,
                              Thanks for posting your logs. Have you already tried following the license repair steps in this Knowledge Base article?
                              http://kb2.adobe.com/cps/405/kb405970.html#LicensingServiceUpdate
                              Looking at the specific error shown in your logs, the primary error entries are these two:
                              According to the KB article above, running the Adobe License Repair Tool is the recommended solution for error numbers in that particular range. Please give that a try, if you haven't already, and let us know how it goes.
                              -Chris
                              • 14. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                olive009 Level 1
                                I've gave up. I reinstalled my Operation System,and it seems to be OK.
                                • 15. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                  Vijayraj Bhatt Level 1
                                  Flash Builder & Flash Catalyst Beta on Vista - shows
                                  "licensing for this product has stop working"'
                                  make sure you "Run as Administrator"
                                  it solved problem of both Error 6 and Error 147:20.
                                  On windows XP, you need to have admin Rights,
                                  it may allow you to install, but may not run and show Error 6 or error 147:20 of licensing for this product has stop working.
                                  enjoy.
                                  • 16. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                    Macnimation Level 1
                                    I have just installed Flash builder 4 beta and it asks me for  a serial number and tells me that the trial has expired?
                                    I have resintalled several times and I get the same thing.
                                    This machine has never had any Flex versions on it before.
                                    XP SP3
                                    Ideas?
                                    • 17. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                      A2zero Level 1
                                      I 'm having the same error on Vista 64, whern tring to run Flash Catalyst. I can make it work by rigth clicking the Fc icon and selecting "run as administrator", but I have to do this every time I want to open Fc.
                                      • 18. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                        Hi A2zero,
                                        With Flash Catalyst, are you running in Trial mode, or did you enter the Beta serial number from the download page?
                                        -Chris
                                        • 19. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                          A2zero Level 1
                                          Hi Chris!
                                          I was running it on Trial mode, it showed me, every time I open it as admin,
                                          the screen that asks if I want to trial or serial.  I entered the beta
                                          serial, still doesn't work without running it as administrator, but it no
                                          longer asks if I want to trial or serial.
                                          2009/6/12 C. Agruss <forums@adobe.com>
                                          Hi A2zero,
                                          -Chris
                                          • 20. Re: Flash Builder can't lanch and promotes "licensing for this product has stop working"
                                            bettina_maria Level 1
                                            I have uninstalled, rebooted, run the License Recovery tool, re-installed and it still doesn't work.  Here is the log information recorded in the amt.log file:
                                            2009-11-18 11:54:31 [2820]  AMT: Application is serialized.
                                            2009-11-18 11:54:31 [2820]  AMT: First launch (serial [95230700665031915420]).
                                            2009-11-18 11:54:31 [2820]  AMT: Application state initialized.  Obtaining Product License.
                                            2009-11-18 11:54:31 [2820]  AMT: Obtaining client features from cache.
                                            2009-11-18 11:54:31 [2820]  AMT: Obtaining client product info from cache.
                                            2009-11-18 11:54:31 [2820]  AMT: Forcing first launch workflow because product is not licensed from previous launch.
                                            2009-11-18 11:54:31 [2820]  AMT: AMT: Obtaining Product License.
                                            2009-11-18 11:54:31 [2820]  AMT: Launch Workflow not yet done in foreground in this session.
                                            2009-11-18 11:54:31 [2820]  AMT: Starting First Launch Workflow
                                            2009-11-18 11:54:31 [2820]  config: No media tag found for payload FlashBuilder-Installer-AdobeCode
                                            2009-11-18 11:54:31 [2820]  config: Using default media policy RET
                                            2009-11-18 11:54:31 [2820]  AMT: Suppressing EULA display on requst
                                            2009-11-18 11:54:31 [2820]  AMT: Starting ALM workflow.
                                            2009-11-18 11:54:31 [2820]  AMT: Initializing ALM for serialized activation.
                                            2009-11-18 11:54:31 [2820]  ALMService: Initializing as licensed app
                                            2009-11-18 11:54:31 [2820]  ALMService: Setting FNP path to C:\Program Files\Adobe\Adobe Flash Builder Beta 2\plugins\com.adobe.flexide.amt_4.0.0.253292\os\win32\x86
                                            2009-11-18 11:54:31 [2820]  ServiceLoader: Removing reference to library adobelm.dll
                                            2009-11-18 11:54:31 [2820]  ServiceLoader: Unloading library adobelm.dll
                                            2009-11-18 11:54:31 [2820]  ALMService: ALM_Initialize error 147:20 (Errno = 2)
                                            2009-11-18 11:54:31 [2820]  AMT: ALM failed to initialize and read trusted storage, hence no license.
                                            2009-11-18 11:54:31 [2820]  AMT: Starting Data Collection for SWTag_Init()
                                            2009-11-18 11:54:31 [2820]  AMT: DoISOTagging() will not be performed as there is no FLMap LEID against FlashBuilder-4.0-Win-PR
                                            2009-11-18 11:54:31 [2820]  performance: AMTObtainProductLicense took 58.120235 ms
                                            2009-11-18 11:54:33 [2820]  AMT: Pre-Validating Product License.
                                            2009-11-18 11:54:33 [2820]  AMT: Services already loaded in this session.
                                            2009-11-18 11:54:33 [2820]  performance: AMTPreValidateProductLicense took 0.145829 ms
                                            2009-11-18 11:54:33 [2820]  AMT: AMT: Validating Product License.
                                            2009-11-18 11:54:33 [2820]  AMT: Launch Workflow already done in this session.
                                            2009-11-18 11:54:33 [2820]  AMT: Checking client features against cache.
                                            2009-11-18 11:54:33 [2820]  AMT: Silent licensing failure during feature checks, hence no license.
                                            2009-11-18 11:54:33 [2820]  AMT: Validating client product info against cache.
                                            2009-11-18 11:54:33 [2820]  AMT: Product is unlicensed.
                                            2009-11-18 11:54:33 [2820]  AMT: DoISOTagging() called more than once for the same license state! Old State = 0, New State = 0
                                            2009-11-18 11:54:33 [2820]  AMT: Failure Validating Product License!
                                            2009-11-18 11:54:33 [2820]  performance: AMTValidateProductLicense took 17.890263 ms
                                            Please help!
                                            • 21. Me too
                                              poyeehamwang Level 1
                                              2009-12-09 22:50:03 [492]  AMT: START SESSION, library version 2.0.1.10077,53.352460
                                              2009-12-09 22:50:03 [492]  AMT: Initializing C:\Program Files\Adobe\Adobe Flash Builder Beta 2\
                                              2009-12-09 22:50:03 [492]  AMT: Adobe License Manager version 3.0 (build 11.10077) RELEASE
                                              2009-12-09 22:50:03 [492]  PCD thread: PCD thread started
                                              2009-12-09 22:50:03 [492]  PCDService: PCD Service in threaded mode
                                              2009-12-09 22:50:03 [492]  performance: AMTPreObtainProductLicense took 8.360559 ms
                                              2009-12-09 22:50:03 [492]  AMT: App Product Locale [0] = zh_CN
                                              2009-12-09 22:50:03 [492]  AMT: App Product Locale [1] = en_US
                                              2009-12-09 22:50:03 [492]  config: Loading configuration for C:\Program Files\Adobe\Adobe Flash Builder Beta 2\AMT\application.xml
                                              2009-12-09 22:50:03 [492]  config: Found default (non-installed) payload code FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  config: Failed to find install-time driver payload; payload acts as its own driver
                                              2009-12-09 22:50:03 [492]  config: Falling back to file-based license configuration
                                              2009-12-09 22:50:03 [492]  config: Setting current license to the driver at startup because no mapping was found.
                                              2009-12-09 22:50:03 [492]  config: Setting current license to FlashBuilder-4.0-Win-PR [ALL]
                                              2009-12-09 22:50:03 [492]  config: payload code: FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  config: driver payload code: FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  config: driver licensing code: FlashBuilder-4.0-Win-PR
                                              2009-12-09 22:50:03 [492]  config: current licensing code: FlashBuilder-4.0-Win-PR
                                              2009-12-09 22:50:03 [492]  config: current locale code: ALL
                                              2009-12-09 22:50:03 [492]  config: Done loading configuration
                                              2009-12-09 22:50:03 [492]  config: Setting insalled locales
                                              2009-12-09 22:50:03 [492]  config: Changing locale to "zh_CN" because old locale "" is not in the new list of installed languages
                                              2009-12-09 22:50:03 [492]  AMT: config: Finding license info for payload: FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  AMT: config: PayloadCode: FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  AMT: config: Driver PayloadCode: FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  AMT: config: Installed LicensingCode: FlashBuilder-4.0-Win-PR
                                              2009-12-09 22:50:03 [492]  AMT: config: Updates are suppressed.
                                              2009-12-09 22:50:03 [492]  AMT: config: No BridgeTalkCode found in configuration; Bridgetalk will be disabled.
                                              2009-12-09 22:50:03 [492]  AMT: Application is serialized.
                                              2009-12-09 22:50:03 [492]  AMT: First launch (serial [95230700665031915420]).
                                              2009-12-09 22:50:03 [492]  AMT: Application state initialized.  Obtaining Product License.
                                              2009-12-09 22:50:03 [492]  AMT: Obtaining client features from cache.
                                              2009-12-09 22:50:03 [492]  AMT: Obtaining client product info from cache.
                                              2009-12-09 22:50:03 [492]  AMT: Forcing first launch workflow because product is not licensed from previous launch.
                                              2009-12-09 22:50:03 [492]  AMT: AMT: Obtaining Product License.
                                              2009-12-09 22:50:03 [492]  AMT: Launch Workflow not yet done in foreground in this session.
                                              2009-12-09 22:50:03 [492]  AMT: Starting First Launch Workflow
                                              2009-12-09 22:50:03 [492]  config: No media tag found for payload FlashBuilder-Installer-AdobeCode
                                              2009-12-09 22:50:03 [492]  config: Using default media policy RET
                                              2009-12-09 22:50:03 [492]  AMT: Suppressing EULA display on requst
                                              2009-12-09 22:50:03 [492]  AMT: Starting ALM workflow.
                                              2009-12-09 22:50:03 [492]  AMT: Initializing ALM for serialized activation.
                                              2009-12-09 22:50:03 [492]  ALMService: Initializing as licensed app
                                              2009-12-09 22:50:03 [492]  ALMService: Setting FNP path to C:\Program Files\Adobe\Adobe Flash Builder Beta 2\plugins\com.adobe.flexide.amt_4.0.0.253292\os\win32\x86
                                              2009-12-09 22:50:03 [492]  ServiceLoader: Removing reference to library adobelm.dll
                                              2009-12-09 22:50:03 [492]  ServiceLoader: Unloading library adobelm.dll
                                              2009-12-09 22:50:03 [492]  ALMService: ALM_Initialize error 147:20 (Errno = 2)
                                              2009-12-09 22:50:03 [492]  AMT: ALM failed to initialize and read trusted storage, hence no license.
                                              2009-12-09 22:50:03 [492]  AMT: Starting Data Collection for SWTag_Init()
                                              2009-12-09 22:50:03 [492]  AMT: DoISOTagging() will not be performed as there is no FLMap LEID against FlashBuilder-4.0-Win-PR
                                              2009-12-09 22:50:03 [492]  performance: AMTObtainProductLicense took 159.584534 ms
                                              2009-12-09 22:50:06 [492]  AMT: Pre-Validating Product License.
                                              2009-12-09 22:50:06 [492]  AMT: Services already loaded in this session.
                                              2009-12-09 22:50:06 [492]  performance: AMTPreValidateProductLicense took 0.150857 ms
                                              2009-12-09 22:50:06 [492]  AMT: AMT: Validating Product License.
                                              2009-12-09 22:50:06 [492]  AMT: Launch Workflow already done in this session.
                                              2009-12-09 22:50:06 [492]  AMT: Checking client features against cache.
                                              2009-12-09 22:50:06 [492]  AMT: Silent licensing failure during feature checks, hence no license.
                                              2009-12-09 22:50:06 [492]  AMT: Validating client product info against cache.
                                              2009-12-09 22:50:06 [492]  AMT: Product is unlicensed.
                                              2009-12-09 22:50:06 [492]  AMT: DoISOTagging() called more than once for the same license state! Old State = 0, New State = 0
                                              2009-12-09 22:50:06 [492]  AMT: Failure Validating Product License!
                                              2009-12-09 22:50:06 [492]  performance: AMTValidateProductLicense took 50.695549 ms
                                              Please help!
                                              • 22. Re: Me too
                                                I looked up that error code (147) here:
                                                One thing it suggests, that I don't know if you've tried, is stopping and restarting the service described here:
                                                Solution 2 (Windows only): Set the FLEXnet Licensing Service to Manual and Start the service.
                                                1. Choose Start > Control Panel.
                                                2. Double-click Administrative Tools.
                                                3. Double-click Services.
                                                4. Double-click the FLEXnet Licensing Service to open the Properties dialog box.
                                                5. Click the Startup Type menu, and then select Manual.
                                                6. Click Apply.
                                                7. In the Services Status section, click Start to start the service.
                                                8. Click Apply, and then click OK.
                                                9. Close all open dialogs.
                                                10. Launch Adobe Acrobat 9 or an Adobe Creative Suite 4 product.
                                                • 23. Re: Me too
                                                  Thanks!
                                                  I found no  FLEXnet Licensing Service in my  Services and I installed it.Now the Flash Builder worked.
