2 Replies Latest reply on Jun 2, 2009 12:34 PM by piercer2
    Wrong Error
    piercer2
      I have the following code in a class
      var nodes:Vector.<Node> = collection.getParents();
      var parentCategory:Node = nodes[nodes.length-2];
      Flash Builder 4 reports the following error
      Description Resource Path Location Type
      1067: Implicit coercion of a value of type org.fwp.models:Node to an unrelated type org.fwp.models:Node. TitleBarMediator.as FWGCollectionViewer(SVN)/src/org/fwg/collectionviewer/view/titlebar line 56 Flex Problem
      Node is a model class and getParents does return a vector of nodes.
      Flex Builder 3 correctly did not point out any errors in this code.
      So is this a bug?
      Conrad
        • 1. Re: Wrong Error
          Jason San Jose Adobe Employee
          Hi Conrad,
          That does seem a bit odd. Anyhow, it would be a SDK 4 compiler bug against mxmlc and/or compc, not Flash Builder.
          Where is the AS type for your "collections" variable defined? Could it be that you have 2 different versions of org.fwp.models.Node in your library path? I tried a trivial example with only the SDK in my library path and saw no errors.
          Jason San Jose
          Quality Engineer, Flash Builder
          • 2. Re: Wrong Error
            piercer2 Level 1
            Thanks, it was exactly that - a project and a swc file conflicting.
