11 Replies Latest reply on Jun 5, 2009 12:24 AM by felicitam
    Unable to run project!!
    felicitam
      Hi;
      I have imported a photoshop file to flash catalyst beta and when I convert a graphic to button, it cannot be run.
      When I drow a simple graphic and convert it to component, I have the same problem too!Untitled-1.png
        • 1. Re: Unable to run project!!
          felicitam Level 1
          and when im trying to open up this tutorials project files i have this error:
          "flash catalyst cannot open this project because it was created by incompatible version of adobe catalyst"
          How can I fix this problems?
          Thanks in advance
          • 2. Re: Unable to run project!!
            Peter Flynn (Adobe) Adobe Employee
            Re your first post: Looks like you hit a bug.  We'd like to look at the PSD file that triggers this error.  Is it something you'd be willing to post on the forum here?
            Re your second post: We'll work on getting that tutorial fixed ASAP.
            The "null pointer" error you see after that is an additional bug (we don't gracefully handle problems opening an FXP that you double-clicked to open).  We'll be sure to have that fixed for the next public preview.
            - Peter
            (Flash Catalyst team)
            • 3. Re: Unable to run project!!
              felicitam Level 1
              The photoshop file is here
              I have the same problem when drawing an art work in catalyst and try to run.
              • 4. Re: Unable to run project!!
                Eric Lopatin (Adobe) Level 2
                Thanks for sending a link to the PS file. One note about importing it – you'll want to choose Image Layers>Flatten in the import dialog to preserve the appearance of layer effects applied to the header artwork. After I created a component out of the "News" button the project ran successfully. I'll chat with Peter and we'll get back to you soon.
                Also, an updated copy of the FXP has been posted for this tutorial:
                http://www.adobe.com/devnet/flashcatalyst/articles/get_started_with_flash_catalyst.html
                -Eric
                (Flash Catalyst QE)
                • 5. Re: Unable to run project!!
                  Can you verify the version Flash Player that's running on your system? Just browse to: http://kb2.adobe.com/cps/155/tn_15507.html
                  and let us know if you have 10.0.12.36 (debug)
                  Also if possible could you please post Catalyst's log file, found here:
                  C:\Users\YourAccountName\AppData\Roaming\Adobe\Flash Catalyst\workspace\.metadata
                  Thanks!
                  -Eric
                  • 6. Re: Unable to run project!!
                    kennyisdead
                    I have the following message each time I try to run project.
                    Nota: I have Flex Builder 3 installed on my computer not Flex Builder 4.
                    • 7. Re: Unable to run project!!
                      felicitam Level 1
                      This is my player version,
                      log file (i cant post txt file in forum)
                      !SESSION 2009-06-02 00:49:49.766 -----------------------------------------------
                      eclipse.buildId=unknown
                      java.version=1.6.0_01
                      java.vendor=Sun Microsystems Inc.
                      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=tr_TR
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 00:50:04.692
                      !MESSAGE Warnings while parsing the key bindings from the 'org.eclipse.ui.commands' extension point
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 00:50:04.692
                      !MESSAGE Could not parse key sequence: plug-in='com.adobe.thermo', id='com.adobe.thermo.fxp.SaveAs', keySequence='M1+Shift+S'
                      !MESSAGE Could not parse key sequence: plug-in='com.adobe.thermo', id='com.adobe.thermo.guides.SnapToGrid', keySequence='M1+Shift+''
                      !MESSAGE Could not parse key sequence: plug-in='com.adobe.thermo', id='com.adobe.thermo.guides.SnapToGuides', keySequence='M1+Shift+;'
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 00:50:12.555
                      !MESSAGE Could not locate the running profile instance
                      !ENTRY org.eclipse.ui 4 4 2009-06-02 00:52:39.138
                      !MESSAGE Plug-in 'org.eclipse.ui.editors' contributed an invalid Menu Extension (Path: 'navigate' is invalid): org.eclipse.ui.edit.text.gotoLastEditPosition
                      !SESSION 2009-06-02 00:54:00.317 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 00:55:49.447
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 00:55:49.447
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 00:55:55.493
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:00:46.115
                      !MESSAGE Launch failure: File not found: file:/C:/Users/ti/Application%20Data/Adobe/Flash%20Catalyst/workspace/biglayout/bin-debug /Main.html
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:02:27.210
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:03:03.743
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:04:19.659
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:06:51.569
                      !MESSAGE Launch failure: File not found: file:/C:/Users/ti/Application%20Data/Adobe/Flash%20Catalyst/workspace/Untitled_1/bin-debu g/Main.html
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:07:19.132
                      !ENTRY org.eclipse.debug.core 4 5012 2009-06-02 01:07:51.632
                      !MESSAGE Failed to delete launch configuration.
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:07:52.075
                      !MESSAGE Undo Transaction Nesting error
                      !STACK 0
                      java.lang.Exception
                          at com.adobe.flexbuilder.project.internal.FlexProjectCore.log(FlexProjectCore.java:716)
                          at com.adobe.flexbuilder.util.logging.GlobalLogImpl.log(GlobalLogImpl.java:37)
                          at com.adobe.flexbuilder.util.logging.GlobalLog.log(GlobalLog.java:21)
                          at com.adobe.thermo.undo.ThermoBatchingHelper.endUndoTransactionSub(ThermoUndoSystem.java:50 1)
                          at com.adobe.thermo.undo.ThermoBatchingHelper.endSupplementalUndoTransaction(ThermoUndoSyste m.java:446)
                          at com.adobe.thermo.undo.ThermoUndoSystem.endSupplementalUndoTransaction(ThermoUndoSystem.ja va:104)
                          at com.adobe.thermo.effects.TransitionManager.incrementalUpdateSelectedTransition(Transition Manager.java:855)
                          at com.adobe.thermo.effects.TransitionManager.access$13(TransitionManager.java:810)
                          at com.adobe.thermo.effects.TransitionManager$ModelChangedListener$1.run(TransitionManager.j ava:635)
                          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:133)
                          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3800)
                          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3425)
                          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2382)
                          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
                          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2198)
                          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
                          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:288)
                          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:488)
                          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
                          at com.adobe.thermo.application.ThermoApplication.start(ThermoApplication.java:90)
                          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
                          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
                          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
                          at java.lang.reflect.Method.invoke(Unknown Source)
                          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
                          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
                          at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:09:40.171
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:10:01.780
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:12:02.395
                      !SESSION 2009-06-02 01:15:06.044 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\biglayout.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\biglayout.fxp
                      !ENTRY org.eclipse.core.resources 2 10035 2009-06-02 01:15:08.869
                      !MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:15:48.976
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:15:58.534
                      !ENTRY org.eclipse.ui 4 4 2009-06-02 01:16:37.765
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 01:17:37.907
                      !MESSAGE Error deleting or modifying launch configuration "Main" while deleting or renaming a project. You may want to edit it manually.
                      !STACK 1
                      org.eclipse.debug.core.DebugException: Failed to delete launch configuration.
                          at org.eclipse.debug.internal.core.LaunchConfiguration.delete(LaunchConfiguration.java:234)
                          at com.adobe.flexide.launching.LaunchCleanupJob.run(LaunchCleanupJob.java:85)
                          at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
                      !SUBENTRY 1 org.eclipse.debug.core 4 5012 2009-06-02 01:17:37.908
                      !SESSION 2009-06-02 10:22:28.124 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 10:24:34.120
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 10:24:34.120
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 10:24:45.622
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 10:27:36.183
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 10:28:25.461
                      !SESSION 2009-06-02 13:30:52.118 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\fcfb2\twitSearch_DONE.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\fcfb2\twitSearch_DONE.fxp
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 13:31:08.592
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 13:31:08.592
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 13:31:34.104
                      !MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.ui.workbench".
                      !STACK 0
                      java.lang.NullPointerException
                          at com.adobe.thermo.hud.HUDCommands$1.perspectiveActivated(HUDCommands.java:504)
                          at com.adobe.thermo.hud.HUDCommands$3.windowOpened(HUDCommands.java:78)
                          at org.eclipse.ui.internal.Workbench$10.run(Workbench.java:763)
                          at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
                          at org.eclipse.ui.internal.Workbench.fireWindowOpened(Workbench.java:761)
                          at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1228)
                          at org.eclipse.ui.internal.WorkbenchWindow.open(WorkbenchWindow.java:786)
                          at org.eclipse.ui.internal.Workbench$61.runWithException(Workbench.java:3394)
                          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
                          at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
                          at org.eclipse.ui.internal.Workbench$27.runWithException(Workbench.java:1361)
                          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2293)
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 13:31:34.358
                      !SESSION 2009-06-02 13:47:07.803 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\fbfc_assets\employee_app.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\fbfc_assets\employee_app.fxp
                      !ENTRY org.eclipse.core.resources 2 10035 2009-06-02 13:47:10.230
                      !SESSION 2009-06-02 13:47:29.073 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 13:47:42.900
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 13:47:42.900
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 13:47:55.895
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 13:49:52.425
                      !MESSAGE Launch failure: File not found: file:/C:/Users/ti/Application%20Data/Adobe/Flash%20Catalyst/workspace/employee_app/bin-de bug/Main.html
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 13:53:39.937
                      !STACK 1
                      !SUBENTRY 1 org.eclipse.debug.core 4 5012 2009-06-02 13:53:39.938
                      !SESSION 2009-06-02 15:48:33.013 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 15:48:46.333
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 15:48:46.334
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 15:48:51.782
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 15:56:58.674
                      !SESSION 2009-06-02 19:25:37.064 -----------------------------------------------
                      !ENTRY org.eclipse.core.resources 2 10035 2009-06-02 19:25:43.806
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 19:25:55.638
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 19:25:55.638
                      !ENTRY org.eclipse.core.jobs 4 2 2009-06-02 19:26:10.845
                      !MESSAGE An internal error occurred during: "Updating Flash Player trust file for project...".
                      !STACK 0
                          at com.adobe.flexbuilder.project.internal.PlayerTrustStore.getGlobalProjectID(PlayerTrustSto re.java:200)
                          at com.adobe.flexbuilder.project.internal.PlayerTrustStore.setProjectTrustPath(PlayerTrustSt ore.java:112)
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject$5.run(ActionScrip tProject.java:1144)
                      !ENTRY org.eclipse.core.jobs 4 2 2009-06-02 19:26:10.846
                      !STACK 0
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 19:26:10.975
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 19:47:57.740
                      !MESSAGE Error in DesignSurface.syncAlignmentItem: alignment item is not on parent surface
                      !SESSION 2009-06-02 19:48:14.969 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 19:48:39.596
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 19:48:39.596
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 19:48:39.597
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 19:48:43.777
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 19:50:57.405
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 19:53:10.590
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 19:58:46.455
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 20:00:49.543
                      !SESSION 2009-06-02 20:05:50.671 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\Untitled_1.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\Untitled_1.fxp
                      !ENTRY org.eclipse.core.resources 2 10035 2009-06-02 20:05:56.289
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 20:06:31.727
                      !SESSION 2009-06-02 20:12:03.696 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\intro_to_flash_catalyst\sample files\ecotours_site.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\intro_to_flash_catalyst\sample files\ecotours_site.fxp
                      !ENTRY org.eclipse.core.resources 2 10035 2009-06-02 20:12:10.432
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 20:12:25.550
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 20:12:25.550
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-02 20:12:34.111
                      !MESSAGE Error creating actionscript project for Untitled_1
                      !STACK 1
                      org.eclipse.core.runtime.CoreException: Error Loading Project
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.createCoreExcepti on(ActionScriptProject.java:1568)
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.loadDescription(A ctionScriptProject.java:556)
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.<init>(ActionScri ptProject.java:182)
                          at com.adobe.flexbuilder.project.internal.FlexBasedProject.<init>(FlexBasedProject.java:81)
                          at com.adobe.flexbuilder.project.internal.FlexProject.<init>(FlexProject.java:85)
                          at com.adobe.flexbuilder.project.actionscript.ActionScriptCore$2.doCreate(ActionScriptCore.j ava:311)
                          at com.adobe.flexbuilder.project.actionscript.ActionScriptCore$ProjectCreator.run(ActionScri ptCore.java:495)
                          at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:1800)
                          at com.adobe.flexbuilder.project.FlexWorkspaceRunner.run(FlexWorkspaceRunner.java:43)
                          at com.adobe.flexbuilder.project.actionscript.ActionScriptCore$ProjectCreator.safeGetOrCreat e(ActionScriptCore.java:469)
                          at com.adobe.flexbuilder.project.actionscript.ActionScriptCore.getProject(ActionScriptCore.j ava:431)
                          at com.adobe.thermo.core.fxp.FXPCommands.checkProjectRecovery(FXPCommands.java:643)
                          at com.adobe.thermo.core.workspace.WorkspaceManager.workbenchPageActivated(WorkspaceManager. java:131)
                          at com.adobe.thermo.core.ThermoCorePlugin$1.run(ThermoCorePlugin.java:76)
                          at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:178)
                          at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
                          at org.eclipse.swt.widgets.Display.syncExec(Display.java:4251)
                          at com.adobe.thermo.core.ThermoCorePlugin$2.pageActivated(ThermoCorePlugin.java:89)
                          at org.eclipse.ui.internal.PageListenerList$1.run(PageListenerList.java:68)
                          at org.eclipse.core.runtime.Platform.run(Platform.java:880)
                          at org.eclipse.ui.internal.PageListenerList.fireEvent(PageListenerList.java:53)
                          at org.eclipse.ui.internal.PageListenerList.firePageActivated(PageListenerList.java:66)
                          at org.eclipse.ui.internal.WorkbenchWindow.firePageActivated(WorkbenchWindow.java:1268)
                          at org.eclipse.ui.internal.WorkbenchWindow.access$11(WorkbenchWindow.java:1259)
                          at org.eclipse.ui.internal.WorkbenchWindow$25.run(WorkbenchWindow.java:2870)
                          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
                          at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2850)
                          at org.eclipse.ui.internal.WorkbenchWindow$19.runWithException(WorkbenchWindow.java:2167)
                      Caused by: com.adobe.flexbuilder.project.persist.PersistenceException: Error reading persistence file L/Untitled_1/.actionScriptProperties
                          at com.adobe.flexbuilder.project.persist.PersistableSettings.readPersistenceFile(Persistable Settings.java:102)
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProjectSettings.<init>(Ac tionScriptProjectSettings.java:286)
                          at com.adobe.flexbuilder.project.internal.FlexProjectSettings.<init>(FlexProjectSettings.jav a:137)
                          at com.adobe.flexbuilder.project.internal.FlexProject.justCreateDescription(FlexProject.java :156)
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.createDescription (ActionScriptProject.java:571)
                          at com.adobe.flexbuilder.project.internal.FlexProject.createDescription(FlexProject.java:150 )
                          at com.adobe.flexbuilder.project.actionscript.internal.ActionScriptProject.loadDescription(A ctionScriptProject.java:537)
                          ... 58 more
                      Caused by: org.eclipse.core.internal.resources.ResourceException: File not found: C:\Users\ti\Application Data\Adobe\Flash Catalyst\workspace\Untitled_1\.actionScriptProperties.
                          at org.eclipse.core.internal.localstore.FileSystemResourceManager.read(FileSystemResourceMan ager.java:612)
                          at org.eclipse.core.internal.resources.File.getContents(File.java:298)
                          at org.eclipse.core.internal.resources.File.getContents(File.java:287)
                          at com.adobe.flexbuilder.project.persist.PersistableSettings.readPersistenceFile(Persistable Settings.java:56)
                          ... 64 more
                      !SUBENTRY 1 com.adobe.flexbuilder.project 4 43 2009-06-02 20:12:34.112
                      !MESSAGE Error Loading Project
                      !STACK 0
                          ... 64 more
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 20:12:40.026
                      !STACK 0
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 20:12:40.402
                      !SESSION 2009-06-02 20:17:14.053 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 20:17:26.478
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 20:17:26.478
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 20:20:24.924
                      !STACK 0
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 20:20:25.128
                      !SESSION 2009-06-02 20:21:34.957 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 20:21:44.586
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 20:21:44.586
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 20:22:48.020
                      !STACK 0
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 20:22:48.301
                      !SESSION 2009-06-02 20:22:56.305 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-02 20:23:06.216
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-02 20:23:06.216
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 20:23:12.066
                      !STACK 0
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-02 20:23:12.302
                      !ENTRY org.eclipse.ui.workbench 4 2 2009-06-02 20:30:27.037
                      !STACK 0
                          at org.eclipse.ui.internal.PerspectiveListenerList$1.run(PerspectiveListenerList.java:74)
                          at org.eclipse.ui.internal.PerspectiveListenerList.fireEvent(PerspectiveListenerList.java:58 )
                          at org.eclipse.ui.internal.PerspectiveListenerList.firePerspectiveActivated(PerspectiveListe nerList.java:72)
                          at org.eclipse.ui.internal.WorkbenchWindow.firePerspectiveActivated(WorkbenchWindow.java:132 1)
                          at org.eclipse.ui.internal.WorkbenchPage.setPerspective(WorkbenchPage.java:3571)
                          at org.eclipse.ui.internal.WorkbenchPage.busyResetPerspective(WorkbenchPage.java:964)
                          at org.eclipse.ui.internal.WorkbenchPage.access$13(WorkbenchPage.java:868)
                          at org.eclipse.ui.internal.WorkbenchPage$13.run(WorkbenchPage.java:3050)
                          at org.eclipse.ui.internal.WorkbenchPage.resetPerspective(WorkbenchPage.java:3048)
                          at com.adobe.thermo.derived.ResetPerspectiveAction.run(ResetPerspectiveAction.java:56)
                          at org.eclipse.ui.internal.PerspectiveAction.run(PerspectiveAction.java:70)
                          at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
                          at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionI tem.java:583)
                          at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:500)
                          at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java :411)
                          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
                          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
                          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3823)
                          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3422)
                      !SESSION 2009-06-03 10:16:40.086 -----------------------------------------------
                      !ENTRY org.eclipse.ui 2 0 2009-06-03 10:17:46.215
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-03 10:17:46.215
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-03 10:17:56.996
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-03 10:20:30.211
                      !MESSAGE Launch failure: File not found: file:/C:/Users/ti/Application%20Data/Adobe/Flash%20Catalyst/workspace/blue/bin-debug/Main .html
                      !ENTRY org.eclipse.debug.core 4 5012 2009-06-03 10:51:13.999
                      !SESSION 2009-06-03 22:27:38.665 -----------------------------------------------
                      Framework arguments:  C:\Users\ti\Desktop\ecotours_site.fxp
                      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean C:\Users\ti\Desktop\ecotours_site.fxp
                      !ENTRY org.eclipse.ui 2 0 2009-06-03 22:28:25.305
                      !SUBENTRY 1 org.eclipse.ui 2 0 2009-06-03 22:28:25.305
                      !ENTRY org.eclipse.equinox.p2.ui.sdk 2 0 2009-06-03 22:28:49.776
                      !ENTRY com.adobe.flexbuilder.project 4 43 2009-06-03 22:29:03.576
                      !MESSAGE Launch failure: File not found: file:/C:/Users/ti/Application%20Data/Adobe/Flash%20Catalyst/workspace/ecotours_ui/bin-deb ug/Main.html
                      !ENTRY org.eclipse.debug.core 4 5012 2009-06-03 22:32:22.732
                      • 8. Re: Unable to run project!!
                        Thanks for posting the player version screen cap and the log file. The Catalyst installer installs a copy of Player 10.0.12.36. Do you have any other beta products on this workstation which may have installed a newer version of the player?
                        • 9. Re: Unable to run project!!
                          I think the Player version thing might be a red herring.  It looks like you're hitting a bug when you import the project or edit it that's making the underlying Flex code not compile.  Two things that would help us track this down:
                          • After you unsuccessfully try launching, switch to Code view and look at the Problems panel.  Let us know anything you see listed there.
                          • Save your Catalyst project at this point and send us the FXP file.
                          Thanks!
                          - Peter
                          • 10. Re: Unable to run project!!
                            @kennyisdead:
                            It sounds like you might be hitting this problem.  You can try one of the workarounds listed there.
                            Are you using Flash Catalyst when you see this error message?  Or does this occur when you try to launch from Builder?
                            - Peter
                            • 11. Re: Unable to run project!!
                              felicitam Level 1
                              I have installed Gumbo beta in my machine.
                              But in all projects, (very simple projects or projects like this) i see the same error in console:
                              could not resolve <fx:DesignLayer> to a component implementation
