0 Replies Latest reply on Sep 23, 2008 7:28 AM by ANewFlexUser
    Data Tip Rendering difficulties with Flex Charts
    ANewFlexUser Level 1
      I was tasked with producing a combination line/column chart at work recently,and while the basic production was simple enough, I have hit a bit of a snag. Initially, I tried declaring a LineChart, and populating it with a series of Line and Column series. LineCharts don't render Column series at all well, though, so I switched to a ColumnChart instead. This renders all the lines and columns correctly, but I have noticed that ColumnChart doesn't support DataTips the same way LineChart does. In a standard LineChart, when you have multiple data points close to/on top of each other, the data tips for all of those points are rendered when you mouse over the cluster. In a ColumnChart, however, only the data tip that is visually on the top layer is displayed. Does anyone have any suggestions for a workaround?
      Thanks!
