5 Replies Latest reply on Jun 3, 2009 3:47 AM by sstanleyau
    (AS) Having trouble with units in dialog box
    Charlieheinz
      Hi all,
      I'm having trouble with showing the right units in my dialog box: In the "measurement edit box" it will allways say the value in pts.
      Even if I add ", edit units:millimeters}" it goes wrong, because then it will show the converted values of 210 and 297.
      I would simply like it to display, AND USE, 210 mm.
      The other problem is that if I press Cancel, the script will go on and give an error about myPageWidth not defined.
      Below is the current script:
      tell application "Adobe InDesign CS4"
      tell view preferences
      set horizontal measurement units to millimeters
      set vertical measurement units to millimeters
      end tell
      set myDialog to make dialog with properties {name:"Test"}
      tell myDialog
      make dialog column
      tell the result
      make border panel
      tell the result
      make dialog column
      tell the result
      make static text with properties {static label:"Size"}
      end tell
      make dialog column
      tell the result
      make static text with properties {static label:"Width:"}
      make static text with properties {static label:"Height:"}
      end tell
      make dialog column
      tell the result
      set myPageWidthField to make measurement editbox with properties {edit value:210}
      set myPageHeightField to make measurement editbox with properties {edit value:297}
      end tell
      end tell
      end tell
      end tell
      --Show dialog
      set myResult to show myDialog
      if myResult is true then
      --Get the values from the various editboxes.
      set myPageWidth to edit value of myPageWidthField
      set myPageHeight to edit value of myPageHeightField
      else
      destroy myDialog
      end if
      --Make the document
      set myDocument to make document
      tell document preferences of myDocument
      set page height to myPageHeight
      set page width to myPageWidth
      set pages per document to 1
      --Bleed
      set document bleed bottom offset to "0"
      set document bleed top offset to "0"
      set document bleed inside or left offset to "0"
      set document bleed outside or right offset to "0"
      --Slug
      set slug bottom offset to "20mm"
      set slug top offset to "0"
      set slug inside or left offset to "0"
      set slug right or outside offset to "0"
      end tell
      ---Bleed and margin---
      tell master spread 1 of myDocument
      tell margin preferences of pages
      set top to 10
      set left to 10
      set bottom to 10
      set right to 10
      end tell
      end tell
      end tell
      Message was edited by: Charlieheinz (Added AS to title)
