4 Replies Latest reply on Jun 3, 2009 3:22 AM by Celinio
    HTTPService: request on a tag/field
    Celinio
      I have the following XML file that I use as a data source :
      <villes>
           <ville>
                <nom>Paris</nom>
                <region>Ile-de-France </region>
                <departement>Paris</departement>
                <codePostal>75001</codePostal>
           </ville>
           <ville>
                <nom>Bordeaux</nom>
                <region>Aquitaine</region>
                <departement>Gironde</departement>
                <codePostal>33000</codePostal>
           </ville>
      </villes>
      I have a map of France, when a user clicks on Bordeaux, I want to display the region, that is Aquitaine, in a panel.
      How do i request this XML file on a field (tag) ?
      In SQL, it would be something like that :
      Select region from ville where nom="Bordeaux" ==> Aquitaine
      In my code, I already have these lines  :
      <mx:HTTPService id="service" url="data/villes.xml" />
      <mx:DataGrid id="grid" dataProvider="{service.lastResult.villes.ville}" />
      Please not that the event which must display the region is not on the DataGrid.
      Thanks for helping.
        • 1. Re: HTTPService: request on a tag/field
          _Natasha_ Level 4
          it's easier to work with XML data. So you can save you XML data to variable or every time call lastResult from service.
          For geting data you want
          var Villes:XML = XML(service.lastResult.villes);
          var regions:XMLList = villes.ville.(nom == "Bordeaux").region; // get all regions. if regions.length()>0 some data founded
          <mx:HTTPService id="service" url="data/villes.xml" resultFormat="e4x"/>
          • 2. Re: HTTPService: request on a tag/field
            Celinio Level 1
            Thanks a lot.
            Following your advice, I wrote this :
            <mx:HTTPService id="serviceE4X" url="data/villes.xml" showBusyCursor="true" resultFormat="e4x" />
            <mx:Script>
                    <![CDATA[
                    // returns the region of the city
                    public function recupererRegion(city:String):String {
                        var Villes:XMLList = XML(serviceE4X.lastResult).villes.ville;
                        var laregion : String = Villes.ville.(nom == "Bordeaux").region ;
                         return laregion;
                </mx:Script>
            When i call the recupererRegion() function, it does not return anything.
            It should return the region of Bordeaux, since it is hard-coded in the function (instead of city, which i will do when it is working).
            I am not running this app in a web server, so there is no debug mode that would give me the opportunity to see what is in the Villes list.
            How can i do that ?
            Thanks for helping.
            • 3. Re: HTTPService: request on a tag/field
              _Natasha_ Level 4
              As I remember this function don't work with XMLList.
                          var Villes:XML = XML(serviceE4X.lastResult);
                        Alert.show(Villes.toXMLString()); // you can debug this way. check that xml is correct
                        var laregions : XMLList = Villes.ville.(nom == "Bordeaux").region;
                        if (laregions.lenght() > 0)
                          return laregions[0].text() ;
                        else
                           return null;
              Something like this.
              Hope it's helpful.
              • 4. Re: HTTPService: request on a tag/field
                Celinio Level 1
                I found it :
                    var lesVilles:XML = XML(serviceE4X.lastResult);
                     var laregion : String = lesVilles.ville.(nom == city).region ;
                Thanks a lot.
