This content has been marked as final.
Show 3 replies
1. Re: Trying to understand
Newsgroup_User Sep 23, 2008 4:57 PM (in response to Newsgroup_User)You have to set both the callback handler and the instance to 0. Otherwise,
the instance is not being released.
Assuming gmux is and muxtra instance, and #mucb the single callback handler
assigned to it, try:
gMux.setnetmessagehandler(#mucb, 0)
gMux=0
"Dave C" <no@no.com> wrote in message
news:gbblln$cn5$1@forums.macromedia.com...
> While working with the MUS xtra I constantly encounter a slightly annoying
> occurrence and I hope to gain a bit more insight about it.
> I create an instance of the MUS xtra and assign a reference for it to a
> global variable. I then use the WaitForNetConnection, passing a specific
> port number that I want to use.
> As I am developing, I stop the movie to work on some part of the code. I
> then restart the movie, running the script that instantiates the Xtra
> again.
> I then immediately see a "WaitForNetConnection" message come in:
> [#errorCode: -2147216214, #recipients: ["Host"], #senderID: "System",
> #subject: "WaitForNetConnection", #content: <Void>, #timeStamp: 0]
> Typically you only see this message come in when another instance is
> trying to connect via ConnectToNetServer, and the #content normally shows
> the username, password, and movie string instead of being void.
> This only happens after the first time I call WaitForNetCOnnection on the
> same port. In a published piece, this would never happen. But as I am
> developing it happens a lot. It really doesn't stop anything from working
> either. I just want to understand.
> Destroying the instance (by setting variable to 0) doesn't change
> anything. It seems like once a movie opens a connection on a port, that
> port remains open until the movie is closed.
> So if I understand, the first time WaitForNetConnection is called, the
> Xtra opens the port if the port is not in use. The next time it sees the
> port open and passes the message on to the WaitForNetConnection handler I
> have set up regardless of where it is coming from. Is this right?
2. Re: Trying to understand
Newsgroup_User Sep 23, 2008 5:17 PM (in response to Newsgroup_User)You were of course right. That did the trick. I have never seen that
documented anywhere. How in the heck did you know that? -
3. Re: Trying to understand
Newsgroup_User Sep 24, 2008 8:53 AM (in response to Newsgroup_User)> How in the heck did you know that?
Case this wasn't a retorical question,
A combination of trying (back in the day) older and newer documented methods
that didn't work, reading between the lines, and quite some experimenting,
from what I can recall.
news:gbc0ud$p7t$1@forums.macromedia.com...
