6 Replies Latest reply on Jun 3, 2009 1:50 AM by twitskull
    Uploading files to server
    twitskull
      I would like to upload several files to server. I allready wrote my php file for accepting POST's. It works perfectly when I use Filereference and selecting file with browse option. I have event listeners for wathing when specific file is uploaded.
      private function startUpload(booIsFirst:Boolean):void
                      if (booIsFirst)
                          _numCurrentUpload = 0;
                      if (_arrUploadFiles.length > 0)
                          _winProgress = winProgress(PopUpManager.createPopUp(this, winProgress, true));
                          _winProgress.btnCancel.removeEventListener("click", onUploadCanceled);
                          _winProgress.btnCancel.addEventListener("click", onUploadCanceled);
                          _winProgress.title = "Uploading file to " + _strUploadDomain;
                          _winProgress.txtFile.text = _arrUploadFiles[_numCurrentUpload].label;
                          _winProgress.progBar.label = "0%";
                          PopUpManager.centerPopUp(_winProgress);
                          // Variables to send along with upload
                          var sendVars:URLVariables = new URLVariables();
                          sendVars.action = "upload";
                          sendVars.credentials = tbxCredentials.text;
                          var request:URLRequest = new URLRequest();
                          request.data = sendVars;
                          request.url = _strUploadScript;
                          request.method = URLRequestMethod.POST;
                          _refUploadFile = new FileReference();
                          _refUploadFile = _arrUploadFiles[_numCurrentUpload].data;
                          _refUploadFile.addEventListener(ProgressEvent.PROGRESS, onUploadProgress);
                             _refUploadFile.addEventListener(Event.COMPLETE, onUploadComplete);
                          _refUploadFile.addEventListener(IOErrorEvent.IO_ERROR, onUploadIoError);
                            _refUploadFile.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onUploadSecurityError);
                          _refUploadFile.upload(request, "file", false);
      But now I need something different. I have local folder and in it some images that I need to upload to server. I wrote this function and it returns all files in that direcotry
      var imageDirectory:File = File.applicationStorageDirectory.resolvePath("yachtImages");
                      var x:String = "";
                      var dirContents:Array = imageDirectory.getDirectoryListing();
                      for(var i:int=0; i < dirContents.length; i++)
                          x += dirContents[i].name + " " + dirContents[i].size + " bytes\n";
                          _sumSize += dirContents[i].size;
                          _aryImages.push({label: dirContents[i].name, data: "file://" + imageDirectory.nativePath.replace(/\\(\.*)/g, "/") + "/" + dirContents[i].name});
                      lstImages.dataProvider = _aryImages;
      The problem is that I cannot figure out how to use it in my previous example. I just cant create FileReference instance for each file. Is there any easiest way to upload files with posting it to server and still having progress bar.
        • 1. Re: Uploading files to server
          Jeff Swartz Level 3
          You say "I just cant create FileReference instance for each file." The File class extends the FileReference class.
          • 2. Re: Uploading files to server
            twitskull Level 1
            Can you please show me snippet of a code. I am kinda lost here.
            • 3. Re: Uploading files to server
              Jeff Swartz Level 3
              I see. You want to get the data of the File (and the data property of a FileReference or File object is only set if you call the load() method).
              So for a file object, you want to do the following.
              var file:File; // set this to one of the files in the directory.
              var stream:FileStream = new FileStream();
              stream.open(file, FileMode.READ);
              var data:ByteArray = new ByteArray();
              stream.readBytes(data, 0, stream.bytesAvailable);
              stream.close();
              • 4. Re: Uploading files to server
                twitskull Level 1
                I am using it like this now
                private function getImages():void
                                for each (var item:Object in _aryImages)
                                    var file:File = File.applicationStorageDirectory.resolvePath("yachtImages/" + item.label);
                                    stream.close();
                                    var fileref:FileReference = new FileReference();
                                    fileref = file as FileReference;
                                    //fileref = data;
                                    trace(item.label);
                I dont know if I can use it now for uploading via URLRequest? What do I do with data bytearray and what i accomplishe with stream reading? Please a little bit help more
                • 5. Re: Uploading files to server
                  Jeff Swartz Level 3
                  There's no need to even reference the ByteArray data. So you can ignore what I said about reading data via a FileStream object. (Sorry for the confusion.)
                  Simply call the upload() method of each File object. (The File class extends the FileReference class, so File objects have an upload() method).
                  For example:
                  sendVars.credentials = "foo";
                  request.url = "http://localhost/foo";
                  var files:Array = File.documentsDirectory.resolvePath("test").getDirectoryListing();
                  var file:File;
                  for (var i:uint; i < files.length; i++)
                      file = files[i];
                      if (!file.isDirectory)
                          file.upload(request);
                          file.addEventListener(Event.COMPLETE, loaded);
                  function loaded(event:Event):void
                      var file:File = event.target as File;
                      trace(file.name, "uploaded.");
                  • 6. Re: Uploading files to server
                    twitskull Level 1
                    Jeff, thanks for all the help. With your help I solved it now
                    private function init():void
                        sqlConnection = new SQLConnection();
                        sqlConnection.open(dbFile);
                        sqlStat = new SQLStatement();
                        sqlStat.sqlConnection = sqlConnection;
                        var connection = new LocalConnection();
                        connection.allowDomain("*");
                        connection.client = this;
                        connection.connect("_myconnect");
                        loadImages();
                    private var aryImages:Array = new Array();
                    private var intCurrentImageIndex:Number;
                    private var popWinProgress:winProgress;
                    private var currentLocalImage:File;
                    private function loadImages():void
                        var directoryImages:Array = File.applicationStorageDirectory.resolvePath("yachtImages").getDirectoryListing();
                        var currentImageFile:File;
                        var intUploadSize:Number = 0;
                        for (var i:uint; i < directoryImages.length; i++)
                            currentImageFile = directoryImages[i];
                            if (!currentImageFile.isDirectory)
                                aryImages.push(currentImageFile.name);
                                intUploadSize += currentImageFile.size;
                        intUploadSize = int(((intUploadSize / 1024) / 1024) * 100) / 100;
                        lblFilesTotal.text = String(aryImages.length);
                        lblUploadSize.text = String(intUploadSize) + " MB";
                        btnSynchronize.enabled = true;
                    private function uploadToServer(isFirstElement:Boolean):void
                        if (isFirstElement)
                            intCurrentImageIndex = 0;
                        if (aryImages.length > 0)
                            popWinProgress = winProgress(PopUpManager.createPopUp(this, winProgress, true));
                            popWinProgress.btnCancel.removeEventListener("click", onSyncCanceled);
                            popWinProgress.btnCancel.addEventListener("click", onSyncCanceled);
                            popWinProgress.title = "Uploading file to " + tbxServer.text;
                            popWinProgress.txtFile.text = aryImages[intCurrentImageIndex] + " [" + String(intCurrentImageIndex + 1) + " of " + String(aryImages.length) + "]";
                            popWinProgress.progBar.label = "0%";
                            PopUpManager.centerPopUp(popWinProgress);
                            request.url = tbxServer.text + ":" + tbxPort.text + "/" + tbxService.text + "/";
                            currentLocalImage = File.applicationStorageDirectory.resolvePath("yachtImages/" + aryImages[intCurrentImageIndex]);
                            currentLocalImage.addEventListener(ProgressEvent.PROGRESS, onSyncProgress);
                            currentLocalImage.addEventListener(Event.COMPLETE, onSyncComplete);
                            currentLocalImage.addEventListener(IOErrorEvent.IO_ERROR, onSyncIOError);
                            currentLocalImage.addEventListener(SecurityErrorEvent.SECURITY_ERROR, onSyncSecurityError);
                            currentLocalImage.upload(request, "file", false);
                    private function onSyncCanceled(event:Event):void
                        PopUpManager.removePopUp(popWinProgress);
                        popWinProgress == null;
                        currentLocalImage.cancel();
                        clearSync();
                    private function onSyncProgress(event:ProgressEvent):void
                        var intPercent:Number = Math.round((Number(event.bytesLoaded) / Number(event.bytesTotal)) * 100);
                        popWinProgress.progBar.setProgress(intPercent, 100);
                        popWinProgress.progBar.label = intPercent + "%";
                        popWinProgress.progBar.validateNow();
                        if (intPercent > 90)
                            popWinProgress.btnCancel.enabled = false;
                        else
                            popWinProgress.btnCancel.enabled = true;
                    private function onSyncComplete(event:Event):void
                        intCurrentImageIndex++;
                        if (intCurrentImageIndex < aryImages.length)
                            uploadToServer(false);
                            progressAll.setProgress(intCurrentImageIndex + 1, aryImages.length);
                        else
                            Alert.show("File(s) have been uploaded.", "Synchronization completed");
                    private function onSyncIOError(event:IOErrorEvent):void
                        Alert.show("IO Error in uploading file.", "Error");
                        clearSync();
                    private function onSyncSecurityError(event:SecurityErrorEvent):void
                        Alert.show("Security Error in uploading file.", "Error");
                        clearSync();
                    private function clearSync():void
                        currentLocalImage.removeEventListener(ProgressEvent.PROGRESS, onSyncProgress);
                        currentLocalImage.removeEventListener(Event.COMPLETE, onSyncComplete);
                        currentLocalImage.removeEventListener(IOErrorEvent.IO_ERROR, onSyncIOError);
                        currentLocalImage.removeEventListener(SecurityErrorEvent.SECURITY_ERROR, onSyncSecurityError);
