0 Replies Latest reply on Jun 2, 2009 1:24 PM by Peter Farland
    [svn:fx-trunk] 7496: Fixing infinite loop for Integer. MAX_VALUE when passed into SWFEncoder minBits.
    Peter Farland Level 3
      Revision: 7496
      Author:   pfarland@adobe.com
      Date:     2009-06-02 13:23:54 -0700 (Tue, 02 Jun 2009)
      Log Message:
      Fixing infinite loop for Integer.MAX_VALUE when passed into SWFEncoder minBits.
      Also integrating FXGUtils source from build 536268 which includes fixes for:
          - 2327344: missing validation when private is not the last child in fxg file
          - 2327364: Missing validation when elements are present in fxg
          - 2341503: Ellipse with a transform matrix when set as a clip mask clips incorrectly
      QE: Yes, please check that the compiler does not hang for the bug scenario.
      Doc: No
      Checkintests: Pass
      Reviewer: Paul
      Bugs:
      SDK-21433 - Compiler hangs when encoding a SWF value of integer max value
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-21433
      Modified Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContentNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContext.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/MatrixNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/TypeHelper.java
          flex/sdk/trunk/modules/swfutils/src/java/flash/swf/SwfEncoder.java
      Added Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/types/
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/types/FXGMatrix.java
      Removed Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/types/
