3 Replies Latest reply on Jun 3, 2009 4:47 AM by stephan.k
    profiler alternatives?
    stephan.k Level 1
      are there any alternatives to the flex profiler?  I can't get it to work.  It's driving me crazy...
      I keep getting the same error:
      Error: ProfilerAgent.socketDataHandler: unknown command = 60
          at ProfilerAgent/socketDataHandler()[C:\faramir\flex\sdk\modules\profiler3\as\ProfilerAgent. as:1008]
      Every time I go to a flash website this error now shows up.
        • 1. Re: profiler alternatives?
          *Prashant Shelke* Level 4
          WSMonitor is other way to see how much memory Flash player consumes for runtime objects. We cannt say it is alternative as it only show consumption not the Classes & object which are taking memory.
          See follwing steps to start profiler:
          1. Close all browser instances.
          2. Make a change in WEB-INF\flex\flex-config.xml(for web-applications)
               <debug>true</debug>
          3. Give path of SWF http:\\localhost:9090\application.swf
          & ensure you have installed debugger version of flash player(which will get on adobe site lates 10.0.X)
          Hope this will help you.
          Thanks.
          • 2. Re: profiler alternatives?
            stephan.k Level 1
            Hi Prashant
            Thank you again.
            Question:  Where do you give the path to the swf?
            Does the debugging work only for flash player 10 (content debugger)?  I am programming for flash player 9 and have therefore player 9 (content debugger) installed.  I have tried both players without luck, but I was wondering if I should just stick with player 10...?
            Thank you.
            -sk
            • 3. Re: profiler alternatives?
              stephan.k Level 1
              The problem seems to be in the following line in my mm.cfg file:
              PreloadSwf=/Users/stephan/Documents/Flex Builder 3/.metadata/.plugins/com.adobe.flash.profiler/ProfilerAgent.swf?host=localhost&port=8888
              Removing this line will make the swf appear in a new browser, but
              - no objects appear and
              - the console displays a "Socket timeout.".
              - An Error pops up once the browser starts:
              The ProfilerAgent seems to be setup wrong.  This C:\faramis path looks unfamiliar.  Not sure where this has been set.  How can I change this?  Where is the ProfilerAgent API?  Which class makes use of it?
              When I remove the PreloadSwf line from the mm.cfg file, the debugger works.  I get all the traces in the console.  The profiler starts with suspending the application and giving me a few options:
              - Connected from :  oldSite.com   (this option again is some other site I have developped earlier... not sure where this can be set?)
              - Application: http://myapp:888/myapp.swf
              - Enable Memory Profiling...
              - Enable Performance Profiling...
              Then once I hit resume, the console says: "socket timeout".  No objects or classes appear.  The memory profiler seems to be doing something.. not sure though if the line just stays very close to zero...
              -sk
