0 Replies Latest reply on Jun 3, 2009 4:43 AM by Carol L. Frampton
    [svn:fx-trunk] 7514: When you set the 'text' property of RichEditableText to a String that has line-ending sequences such as LF or CR+LF , a TextFlow with multiple paragraph is now produced as the 'content'.
    Carol L. Frampton Level 2
      Revision: 7514
      Author:   cframpto@adobe.com
      Date:     2009-06-03 04:43:00 -0700 (Wed, 03 Jun 2009)
      Log Message:
      When you set the 'text' property of RichEditableText to a String that has line-ending sequences such as LF or CR+LF, a TextFlow with multiple paragraph is now produced as the 'content'. The splitting is done using TLF's importer for PLAIN_TEXT_FORMAT if the 'text' is found to contain \r or \n.  See rev 7480 for more detail.
      Fix bug in importToFlow() which I thought I had already fixed.  The config param should be passed in the call to TextFilter.getImporter().  This impacts whiteSpace processing in content that is a markup string.
      QA Notes:
      Doc Notes:
      Bugs:
      Reviewers: Gordon
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/flex4/src/spark/primitives/RichEditableText.as
