0 Replies Latest reply on Jun 3, 2009 7:49 AM by Rajesh Subbiah
    Using Http Service in Flex components (dynamic loading)
    Rajesh Subbiah Level 1
      Hi all,
      I just want share few things which i learnt when developing an application.
      Whenever you want to dynamically load flex components from server using HttpService,following points will be helpful.
      1. If you to load your data in chart/datagrid (i.e data is not hierarchical ) then you can use following HttpService
              The resultformat must be E4X with proper result handlers. example
              <mx:HTTPService id="srv" resultFormat="E4X" url="http://localhost:8080/SampleWebApp/test.jsp"/>
      2. If you need to load your data in TREE (i.e. data is hierarchical) then the resultFormat must be xml
      Hope this will help you ppl in designing your applications
      Rajesh Subbiah
