I recieved instructions on how to set the tabbing order on a form in the design view and followed them implicitly. However, when I go to the "Preview PDF" view and tab through the form it is not tabbing to two of the fields. I have re-done the tabbing order numerous times bit to no avail. It still skips those two fields, any ideas on how to correct this problem?
Views
Total Likes
Can you post the form and tell us where the two offending fields are?
Paul
Views
Total Likes
I cannot post the form as it is company proprietary information. Basically after properly setting the tabbing order and checking the tabbing sequence in preview it skips 2 fields, which were properly put in sequence in the design view.
Views
Total Likes
Can you copy and paste those fields into a new form (along with some other fields) and see if the problem persists? I am trying to determine if it is an object, or Form issue.
Paul
Views
Total Likes
I have tried that and the issue remains the same
Views
Total Likes
Can you post the test form?
Paul
Views
Total Likes
I will have to create a test form as I said before this is company prprietary information, but there is no guarantee that the test form will have the same issues
Views
Total Likes
