0 Replies Latest reply: Jun 3, 2009 2:45 PM by pmd12345 RSS
    [svn:fx-trunk] 7540: Slight restructuring of the Asc parser/scanner, with the following changes:
    pmd12345 Community Member
      Revision: 7540
      Author:   peted@adobe.com
      Date:     2009-06-03 14:45:44 -0700 (Wed, 03 Jun 2009)
      Log Message:
      recursive list parses are rewritten as iterators
      A direct operator precedence parser is in place
      Context sensitive flags between the scanner and parser have been removed.
      The parsers about 1000 loc shorter, Slightly slower until I get precedence lookup simplified.
      Some asc tests have been updated, since syntax error behavior is slightly improved in some cases.
      QE Notes: All possible test cases should be run
      Doc Notes: None
      Reviewer: Paul
      tests: checkintests tamarin, asc-tests, performance tests
      Modified Paths:
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/MemberExpressionNode.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/NodeFactory.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Parser.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Scanner.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Token.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/parser/Tokens.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/Context.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/ContextStatics.java
          flex/sdk/trunk/modules/asc/src/java/macromedia/asc/util/NamespacesTable.java
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/EmptyNameErr23.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticNameErr23.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/Function/StaticPublicNameErr23.e rr
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/FunctionAccessors/EmptyNameErr23 .err
          flex/sdk/trunk/modules/asc/test/compiler/as3/Definitions/const/ConstErr.err
          flex/sdk/trunk/modules/asc/test/compiler/as3/LocalizedErrors/1196-NoExpressionAfterThrow. err
          flex/sdk/trunk/modules/asc/test/compiler/e4x/TypeConversion/toXMLStringErr.err
          flex/sdk/trunk/modules/asc/test/compiler/sanity/strict/b115412.err
