3 Replies Latest reply on Jun 4, 2009 8:31 AM by kglad
    Data Binding?
    THE SNU66LER
      When I use xml so to create a menu I'm used to binding the XML info to the menu with 'attachMovie' or 'duplicateMovieClip'
      example would be
      <myMenu>
           <tab>
                <tabName>Tab 1</tabName>
                <tabDesc>bla bla</tabDesc>
           </tab>
           <tab>
                <tabName>Tab 2</tabName>
           </tab>
           <tab>
                <tabName>Tab 3</tabName>
           </tab>
      </myMenu>
      After parsing my xml in flash my menu build would look something like this:
      for (i=0; i<myMenu.tab.length; i++) {
           tabData = myMenu.tab[i];
           var tab = myTab.duplicateMovieClip("newTab"+i, i,  tabData );
      My XML data is bound to each tab now. If I traced 'tabName' after a onPress event I would surely get the name of the tab defined in the XML.
      Now, to my question.
      I've created a map of the U.S. Each state is on the stage and now I have to attach information I have in a XML file to each state. Its probably a easy solution, but I can't figure out how to link the two together.
