4 Replies Latest reply on Jun 4, 2009 9:43 PM by mikem75
    Hide cursor over .wmv video
    mikem75 Level 1
      Is there any way to hide the cursor over a .wmv video playing inside a director presentation. I've used the cursor = 200 value and the cursor nicely hides itself everywhere except over the video.  I'd like to hide it there as well.  Thoughts??
      I'm authoring in MX2004 on Windows XP.
      THX
      Mike M
        • 1. Re: Hide cursor over .wmv video
          Dean Utian Adobe Community Professional
          Hi Mike,
          I just tested this by just adding the 'Rollover Cursor Change' behavior to a wmv sprite and to a sprite over the wmv. I found that:
          * On a rollover, the cursor will always be the arrow while the video is playing.
          * If you mouseDown over the wmv, the cursor changes (following the behavior settings)
          * If the video is paused, the cursor that is set with the behavior will work - so you could make it blank.
          So, it looks like that when a WMV is playing, it takes control of the cursor and won't allow you to change it with Lingo.I actually don't like WMVs all that much. particularly through Director.
          Dean
          Director Lecturer / Consultant / Director Enthusiast
          http://www.deansdirectortutorials.com/
          http://www.multimediacreative.com.au
          • 2. Re: Hide cursor over .wmv video
            xz1000m
            Hi, mikem75
                I don't think it is a good method to use .wmv video in Director. The best way to use videos is to import these files into flash, then convert them into .flv format  and export it as a .swf file.
               Then import this .swf video file into Director. You can deal with the video file as a normal sprite. Do everything you can do to it.
            reagrds
            xz1000m
            • 3. Re: Hide cursor over .wmv video
              On the swf and flv front, I have a tutorial on this . It includes a set of template files to use a SWF player that you can link to any FLV with a Director behavior. Also has a behavior for a wait until the end of the FLV and other FLV controls. It can be found at:
              http://www.deansdirectortutorials.com/FlashVideo/
              Dean
              • 4. Re: Hide cursor over .wmv video
                mikem75 Level 1
                Thanks everyone for the help!  Its great to be able talk to other developers and the suggestions are really helpful.  What I ended up doing was using Buddy xtra and just moving the cursor down to the bottom right hand corner of the screen while the video is playing.  For all intents, its not visible at all.
                The project is not a traditional Director application.  Its a kiosk using an I-Viewer from Exhibit Engineering (www.exhibitengineering.com) so things are a bit more complicated.  In this case, the wmv files seemed to work the best and had the smoothest playback as the viewer moved over to their area of the score, so I didn't want to switch to a different video format.
                Check the I-Viewer out, its pretty cool.
                In any event, things are working fine now, the exhibit had a preview party tonight and the app performed flawlessly.
                Thanks again for all the suggestions!
                Mike M
