6 Replies Latest reply on Sep 22, 2008 7:13 PM by wolfv
    Callback function in CF?
    wolfv
      Is there a way to implement a callback function in CF?
      The following pseudo callback function works by passing the function's name as a string.
      Is there a way to pass a function pointer?
      Output of the following code is: in callback function
      Thank you in advance.
        • 1. Re: Callback function in CF?
          Level 7
          > <cffunction name="func">
          > <cfargument name="arg1" type"string">
          > <cfoutput>#Evaluate(arg1)#</cfoutput>
          > </cffunction>
          > <cffunction name="callback_func">
          > </cffunction>
          > <cfoutput>
          > #func("callback_func()")#<br>
          > </cfoutput>
          Don't pass the function's name it, pass the function itself in:
          {code}
          <cfargument name="arg1" type="any"><!--- not really "any" but nothing more
          appropriate to choose from --->
          <cfoutput>#arguments.arg1()#</cfoutput>
          </cffunction>
          </cffunction>
          <cfoutput>
          #func(arg1=callback_func)#<br>
          </cfoutput>
          {code}
          Adam
          • 2. Re: Callback function in CF?
            -==cfSearching==- Level 4
            Cool. Though it is probably worth noting the callback_function has to be in the same context (ie page or cfc).
            • 3. Re: Callback function in CF?
              Level 7
              I'm not sure I follow.
              <!--- c1.cfc --->
              <cfcomponent>
              <cffunction name="f">
              <cfreturn "This is F">
              </cffunction>
              </cfcomponent>
              <!--- c2.cfc --->
              <cfcomponent>
              <cffunction name="g">
              <cfargument name="func" type="any">
              <cfreturn arguments.func()>
              </cffunction>
              </cfcomponent>
              <!--- caller.cfm --->
              <cfset copyF = createObject("component", "c1").f>
              <cfset o = createObject("component", "c2")>
              <cfoutput>#o.g(copyF)#</cfoutput>
              This grabs the f() function out of c1, passes it to g() in c2, where it's
              executed.
              A function (UDF or CFC method) is pretty much just a variable in CF, and
              can be passed around as such.
              You *would* have a problem if f() referred to other methods or variables
              within c1.cfc, because by the time you're running it, it's not the method
              that is the member of an instance of C1; it's just "some ol' function". So
              anything it *references* must be available in whichever scope it ends up
              being.
              Adam
              • 4. Re: Callback function in CF?
                Level 7
                I take that back. Returntype="function" works fine.
                Adam
                • 5. Re: Callback function in CF?
                  > being.
                  Yes, that is it exactly. So if c1.cfc contained this code, the call would fail because variables.someProperty is not in scope.
                  <cfcomponent>
                  <cfset variables.someProperty = "whatever">
                  <cfreturn variables.someProperty>
                  </cffunction>
                  </cfcomponent>
                  • 6. Re: Callback function in CF?
                    wolfv Level 1
                    Thanks Adam, that worked real well.
