2 Replies Latest reply on Aug 26, 2011 9:16 AM by pink2cyan
    Create Application from DB Error creating SQL Model Connection
    migofast Level 1
      Whenever I attempt to use Data -> Create Application from Database I am hit with the following screen:
      I recognize what its trying to connect to as something I worked on a long time ago but it has absolutely nothing to do with the current project. Im not sure which of the errors happen first but assuming its the first error on the list the full details are:
      Error creating JDBC Connection connection to slideshow. (Error: Communications link failure due to underlying exception:
      ** BEGIN NESTED EXCEPTION **
      java.net.SocketException
      MESSAGE: java.net.ConnectException: Connection refused
      STACKTRACE:
      java.net.SocketException: java.net.ConnectException: Connection refused
          at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:156)
          at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:284)
          at com.mysql.jdbc.Connection.createNewIO(Connection.java:2555)
          at com.mysql.jdbc.Connection.<init>(Connection.java:1485)
          at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:266)
          at org.eclipse.datatools.connectivity.db.generic.JDBCConnection.createConnection(JDBCConnect ion.java:87)
          at org.eclipse.datatools.connectivity.DriverConnectionBase.internalCreateConnection(DriverCo nnectionBase.java:104)
          at org.eclipse.datatools.connectivity.DriverConnectionBase.open(DriverConnectionBase.java:53 )
          at org.eclipse.datatools.connectivity.db.generic.JDBCConnectionFactory.createConnection(JDBC ConnectionFactory.java:52)
          at org.eclipse.datatools.connectivity.internal.ConnectionFactoryProvider.createConnection(Co nnectionFactoryProvider.java:77)
          at org.eclipse.datatools.connectivity.internal.ConnectionProfile.createConnection(Connection Profile.java:354)
          at org.eclipse.datatools.connectivity.internal.ManagedConnection.createConnection(ManagedCon nection.java:166)
          at org.eclipse.datatools.connectivity.internal.CreateConnectionJob.run(CreateConnectionJob.j ava:56)
          at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
      ** END NESTED EXCEPTION **
      Last packet sent to the server was 0 ms ago.)
      STACKTRACE:
      If you'd like to see all the details of all the operation errors I can post those as well.
