5 Replies Latest reply: Jan 28, 2011 10:24 AM by John T Smith RSS
    Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
    KJSTech Community Member
      We are having problems specifically with a PC with viewing PDF files in IE 7.0.  Now when viewing PDF files
      on our special inhouse loan funding site, the browser will freeze and eventually an error message will come up "Internet Explorer has encountered an error and needs to close".
      What I tried so far...
      -Ran the Adobe update , it installed Acrobat Professional 9.1.1
      -Did the Reset under the Advanced tab in Internet Properties.
      -Re-enabled the adobe related IE plugins.
      -Deleted everything from the users %temp% file.
      -Rebooted PC
      I've asked our web application vendor if we could use a much better browser such as Firefox, Chrome, or even try IE8, but they said that it's not supported.
      The error shown in the application event log is:
      Event Type:        Error
      Event Source:    Application Error
      Event Category:                None
      Event ID:              1000
      Date:                     6/3/2009
      Time:                     3:11:32 PM
      User:                     N/A
      Computer:          PROC2
      Description:
      Faulting application iexplore.exe, version 7.0.6000.16827, faulting module acropdf.dll, version 9.1.0.163, fault address 0x0000221c.
      For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
      Data:
      0000: 41 70 70 6c 69 63 61 74   Applicat
      0008: 69 6f 6e 20 46 61 69 6c   ion Fail
      0010: 75 72 65 20 20 69 65 78   ure  iex
      0018: 70 6c 6f 72 65 2e 65 78   plore.ex
      0020: 65 20 37 2e 30 2e 36 30   e 7.0.60
      0028: 30 30 2e 31 36 38 32 37   00.16827
      0030: 20 69 6e 20 61 63 72 6f    in acro
      0038: 70 64 66 2e 64 6c 6c 20   pdf.dll
      0040: 39 2e 31 2e 30 2e 31 36   9.1.0.16
      0048: 33 20 61 74 20 6f 66 66   3 at off
      0050: 73 65 74 20 30 30 30 30   set 0000
      0058: 32 32 31 63 0d 0a         221c..
      Followed by:
      Event Type:        Error
      Event ID:              1001
      Date:                     6/3/2009
      Time:                     3:12:12 PM
      User:                     N/A
      Computer:          PROC2
      Description:
      Fault bucket 1230219238.
      Data:
      0000: 42 75 63 6b 65 74 3a 20   Bucket:
      0008: 31 32 33 30 32 31 39 32   12302192
      0010: 33 38 0d 0a               38..
      Thanks for your help!
        • 1. Re: Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
          EdGioja Community Member
          Did you ever get an answer to this?  We are having problems with some documents that open fine in Version 7 and 8, but freeze up in 9.  When I look at the Task Manager, Acrobat is using about 50% of my CPU.  As one test, I let it sit there for 3 hours before I finally killed it.  I don't know how important it is, but the documents we are having problems with are Acroforms, but not all Acroforms are having a problem and not even all instances of THIS form.
          • 2. Re: Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
            We never got any solution to this problem.  We are now up to IE8 and Acrobat 9.4 and it still happens.  Neither Microsoft nor Adobe has fixed this issue in their newer versions.
            Event Type:    Error
            Event ID:    1000
            Date:        1/28/2011
            Time:        10:38:44 AM
            User:        N/A
            Computer:    (name withheld)
            Description:
            Faulting application iexplore.exe, version 8.0.6001.18702, faulting module acropdf.dll, version 9.4.0.195, fault address 0x0003ab82.
            Data:
            0020: 65 20 38 2e 30 2e 36 30   e 8.0.60
            0028: 30 31 2e 31 38 37 30 32   01.18702
            0040: 39 2e 34 2e 30 2e 31 39   9.4.0.19
            0048: 35 20 61 74 20 6f 66 66   5 at off
            0050: 73 65 74 20 30 30 30 33   set 0003
            0058: 61 62 38 32 0d 0a         ab82..
            • 3. Re: Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
              John T Smith CommunityMVP
              Thinking out loud (through keyboard) here...
              When you create the PDF, what are your version settings?
              Have you tried telling Acrobat to create the PDF to a previous version?
              I'm not sure of the exact numbers, but I **think** v9 creates a PDF as version 1.7 by default... do you might go into the options and pick a previous version
              • 4. Re: Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
                Ok, well this is an specialized web based application.  I tried opening the PDF's in a new window on my Windows 7 PC and I got them to open without the infinite loop like on a Windows XP machine.
                Because that causes an infinite loop on Windows XP, we need the PDF to display in browser, which causes a conflict sometimes between IE and Adobe dll files.
                So I've checked out a file that doesn't normally crash the IE/Acrobat9.4 user and checked the properties.
                Application: LiquidOffice Form Designer
                PDF Producer: DocuCom PDF Core Library
                PDF Version: 1.6 (Acrobat 7.x)
                File Size: 253.77 KB
                Now here's the properties of a PDF that intermittently crashes IE:
                Application: Acrobat PDFMaker 8.1 for Word
                PDF Producer: Acrobat Distiller 8.1.0 (Windows)
                File Size: 272.14 KB
                Remember I said intermittently.  That's what's real difficult about the problem.  That same file might open 10 consecutive times before crashing.  OR it might crash on the first try.  When things aren't consistently broken it's very hard to troubleshoot the issue since there is no concrete evidence of a single underlying cause.  If it crashed every single time on that file, maybe we would say that its a corrupt file or there's an issue with the program that produced it.  That's not the case here.
                Good idea as to looking at the version.  We could change the versions but we would need to open a request with the application developer, and updates to some of these forms takes weeks for them to integrate.
                • 5. Re: Random IE7 freeze when opening a PDF from Acrobat 9.1 Pro
                  I also have an intermittent problem of a different nature http://forums.adobe.com/thread/740960?tstart=0
                  I do see that my different problem is with v8.2.5 and you show v8.1
                  So... what about updating the Acrobat that creates the files, to see if that fixes this problem?
