4 Replies Latest reply on Sep 30, 2008 4:04 PM by istrasci
    Default background color issue
    kleptomac
      I am trying to change themes at run-time using StyleManager.loadStyleDeclarations(). Whenever I switch to a theme, the default theme's background color shows up for a fraction of a second. I tried using the "StyleEvent.COMPLETE" event handler but it doesn't seem to work. Is there a way to remove this? I want the transition from my current theme to the next theme to be smooth without the default background color appearing. If anybody can please provide a solution for this, It would be a great help.
      Jai
        • 1. Re: Default background color issue
          Peter Lorent Level 2
          Project -> Properties -> Flex Compiler -> add the default color:
          -default-background-color 0xFFFFFF
          • 2. Re: Default background color issue
            istrasci Level 1
            That's not what he's talking about... He's saying if you load a CSS file with loadStyleDeclarations(), it will momentarily flash the default, green Halo theme before switching to the new style... If I load up my white theme (White.swf -- compiled to swf from css) and then I want to change to my red theme (Red.swf) like:
            StyleManager.unloadStyleDeclarations("White.swf");
            StyleManager.loadStyleDeclarations("Red.swf");
            At the * point in the execution, it will flash the green Halo theme instead of just making a smooth transition from white to red... It doesn't look so professional...
            I have the same problem when switching themes, and it's very annoying... Guess I'll keep an eye on this thread...
            • 3. Re: Default background color issue
              And using -default-background-color 0xFFFFFF sets that to white...
              • 4. Re: Default background color issue
                istrasci Level 1
                OK, but the point is, he (and myself as well), don't want any colour to flash when changing between themes. It should just change Colour1->Colour2, not Colour1->(default colour)->Colour2
