7 Replies Latest reply on Aug 12, 2008 12:45 PM by Newsgroup_User
    Fade line to strong
    Level 7
      http://www.twelveetudes.com/homezzz.php
      Hi.
      I have an image on the above site and I was wondering if there was anyway I
      can make the linear fade look less like a black dividing line and have a
      smoother progression to white?
      Thanks for any pointers
      Brian
        • 1. Re: Fade line to strong
          Level 7
          Do you have the image without the gradient background?
          Peter
          ______________________
          "dw2004" <info@tuttiwebsBOTTOM.ie> wrote in message
          news:g7sf4g$o8t$1@forums.macromedia.com...
          | Hi.
          I
          | Brian
          • 2. Re: Fade line to strong
            Level 7
            Thanks Peter,
            Yep I have it here http://www.twelveetudes.com/home_ng.php
            I hope to apply this to a few pages with different images (all Black and
            White) and was hoping to get a better result than my attempt!
            Thanks again
            Brian
            "PJR" <flash@SLICEreclusivebillionaire.com> wrote in message
            news:g7sir3$s5g$1@forums.macromedia.com...
            > Peter
            > | Hi.
            > anyway
            > I
            > | Brian
            • 3. Re: Fade line to strong
              Level 7
              > and White) and was hoping to get a better result than my attempt!
              Commands>Creative>Fade Image
              This will leave you with your original image overlaid with a graphic
              filled with a linear white to black gradient. You'll see the handle over
              the image. One side has a circle, the other a square. The circle sets
              where the gradient starts; the square sets its angle. The distance
              between the two of them (which is set by dragging the square) sets how
              wide the fade is.
              Play around a bit; you'll hit what you want fairly quickly. I got
              something fairly decent looking with the round dot about a thumbsbreadth
              outside the image and the square dot just under the subject's sideburns.
              Joe Makowiec
              http://makowiec.net/
              Email: http://makowiec.net/contact.php
              • 4. Re: Fade line to strong
                Level 7
                Getting a smoother gradient is no problem, but blending the right (dark)side
                of his face into it will be I think. Leave it with me I'll have a play.
                Peter
                • 5. Re: Fade line to strong
                  Level 7
                  What do you think?
                  http://fasterthanu.com/misc_images/FinghinCollins.png
                  Lost a fair bit of contrast, but best I can do, unless you can get rid of
                  the background altogether. That is the FWs png so you can play around with
                  it yourself. I used the Stamp blend mode.
                  Peter
                  _______________________
                  news:g7sk60$9n$1@forums.macromedia.com...
                  (dark)side
                  | Peter
                  • 6. Re: Fade line to strong
                    Level 7
                    Thanks so much Peter I've uploaded that and it's far better.
                    http://www.twelveetudes.com/homezzz.php for yourself!.
                    Not sure I have stamp Blend mode on my old FWMX but I'm going to play with
                    what you sent me and see if I can do similar to other images.
                    Great help thank you
                    Brian
                    • 7. Re: Fade line to strong
                      Level 7
                      No problem, I think it looks great, very moody :-) I was actualy
                      using FWsCS4 beta, so you may even have a problem opening it in FWs.
                      Let me know if you do. Good luck.
                      Peter
                      _________________
