4 Replies Latest reply on Jun 6, 2009 8:18 PM by crumsberry
    What is the exact format that this code generates?
    crumsberry
      What si the exact format this code generates? I cant tell. I need to know so that I can put my own set of dates into an array and have it accept that from a database.
      <mx:Script>
      <![CDATA[
      import mx.formatters.DateFormatter;
      import mx.core.mx_internal;
      [Bindable]
      private var input:Array = [];
      private function generateDates():void
      var today:Date = new Date();
      var monthSeconds:Number = 30*24*60*60*1000;
      //let us generate random special dates for previous 2 months from today
      for (var i:int = 0; i < 10; ++i)
      input.push(new Date(today.time - Math.random()*monthSeconds*2))
      //let us generate random special dates for next 2 months from today
      input.push(new Date(today.time + Math.random()*monthSeconds*2))
      dch.specialDates = input;
      </mx:Script>
        • 1. Re: What is the exact format that this code generates?
          crumsberry Level 1
          Sorry, what I meant to say is: what is the exact format that input:Array is in once it is populated?
          • 2. Re: What is the exact format that this code generates?
            GordonSmith Level 4
            Your code makes input:Array contain 20 Date objects. A Date object does not really have a "format"; it internally just stores the number of milliseconds since 1/1/1970 but has properties for the year, month, day, hour, etc. If you need to construct a Date object for a particular date like June 6, 2009 you can do "new Date(2009, 5, 6)".
            Gordon Smith
            Adobe Flex SDK Team
            • 3. Re: What is the exact format that this code generates?
              crumsberry Level 1
              Wouldn't this do the trick then?????
              It gets its mysql data from: www.chugachexpress.com/php/filldates.php
                [Bindable]
                private var tmp_string:String = "";
                    [Bindable]
              public var input:Array = [];
                    public function fdresultHandler(event:ResultEvent):void
                        tmp_string = event.result as String;
                        var input:Array = tmp_string.split(",");
                       for (var i:int = 0; i < input.length; i++)
                           input[i] = new Date(DateField.stringToDate(input[i], "EEE MMM D HH:NN:SS GMT-0800 YYYY"));
                          input.pop();
                           datechooserM.specialDates = input;
              • 4. Re: What is the exact format that this code generates?
                crumsberry Level 1
                Used this code to get specific dates: Thanks
                public function fdresultHandlerG(event:ResultEvent):void
                          tmp2_string = event.result as String;
                          var datesArrayTemp:Array = tmp2_string.split("&");
                         for each(var value:* in datesArrayTemp)
                             datesArray.push(new Date(DateField.stringToDate(value, "YYYY, MM, DD")));
                             datechooserG.specialDates = datesArray;
