2 Replies Latest reply on Jun 5, 2009 9:16 AM by _Natasha_
    How to access this XML data in a grid?
    Handycam Level 1
      I have done many data grids, but for some reason I am getting stuck on how to display this particular XML data in a grid correctly:
      <?xml version="1.0" encoding="UTF-8"?>
      <tableData>
      <items type="Kitchen access">
      <item><![CDATA[Direct; less than 3 ft. above grade]]></item>
      <item><![CDATA[Direct; one story above grade]]></item>
      <item><![CDATA[Indirect; less than 3 ft. above grade]]></item>
      <item><![CDATA[Indirect; one story above grade]]></item>
      <item><![CDATA[Indirect; more than one story above grade]]></item>
      </items>
      <items type="Flooring removal">
      <item><![CDATA[Flooring to remain]]></item>
      <item><![CDATA[Remove sheet vinyl or linoleum]]></item>
      <item><![CDATA[Remove tile on mortar bed]]></item>
      <item><![CDATA[Remove wood flooring]]></item>
      <item><![CDATA[Remove any floor installed with tenacious adhesive]]></item>
      </items>
      ...etc...
      </tableData>
      I want each "items" to be a row, and then each "item" a column within that row.  Is this possible, or should I reformat the XML?
        • 1. Re: How to access this XML data in a grid?
          Gaurav J Adobe Employee
          Its possible. Let say your xml is in a seperate file, try :
              <mx:XML id="tableData" source="tableData.xml"/>
               <mx:DataGrid id="dgId" dataProvider="{tableData.items}" editable="true" height="100" width="100%" />
          HTH,
          Gaurav Jain
          Flex SDK Team
          • 2. Re: How to access this XML data in a grid?
            _Natasha_ Level 4
            this way only type attribute will be shown.
            You can show your data using labelFunction property of column.
            <mx:Script>
            <![CDATA[
            private function myLabel(item:Object, column:DataGridColumn):String
            var n:Number = Number(column.dataField); // number of child to show
            var s:String = XML(item).item[n].toString(); // value
            return s;
            </mx:Script>
            <mx:XML id="dgData" xmlns="">
            <tableData>
            </items>
            </items>
            </tableData>
            </mx:XML>
            <mx:DataGrid dataProvider="{dgData.items}">
            <mx:columns>
            <mx:DataGridColumn headerText="Column 1" labelFunction="myLabel" dataField="0">
            </mx:DataGridColumn>
            <mx:DataGridColumn headerText="Column 2" dataField="1" labelFunction="myLabel"/>
            <mx:DataGridColumn headerText="Column 3" dataField="2" labelFunction="myLabel"/>
            </mx:columns>
            </mx:DataGrid>
