0 Replies Latest reply on Jun 5, 2009 11:56 AM by Zolotoj
    ComboBox in grid
    Zolotoj Level 3
      Here is my column:
      <mx:DataGridColumn
      headerText="Name" editorDataField="selectedValue"
      width="
      {accounts.width*.9}"
      dataField="
      ccompany">
      </mx:DataGridColumn>
      ItemEditor:
      [Bindable]
      var availAccounsEditor:ClassFactory = new ClassFactory(comboItemRenderer);
      private function populateSalesRepsAccounts(resultXML:XML, dummy:Object):void
      var availAccounts:DataGridColumn = accounts.columns[0];
      availAccounsEditor.properties = {labelField :
      "ccompany", dataProvider : resultXML.customers};
      availAccounts.itemEditor = availAccounsEditor;
      ItemEditor:
      package
      modulecode
      import flash.events.Event;
      import mx.collections.*;
      import mx.controls.*;
      import mx.controls.listClasses.*;
      import mx.events.*;
      public class comboItemRenderer extends ComboBox implements
      IDropInListItemRenderer
      private var
      _selectedValue:String;
      private var bSelectedValueSet:Boolean = false;
      private var bDataProviderSet:Boolean = false;
      public var dataProviderCopy:Object = new Object;
      public function comboItemRenderer()
      super();
      override public function set dataProvider(value:Object):void
      super.dataProvider = value;
      // This may get called before dataProvider is set, so make sure not null and has entries
      if (value!=null && value.length)
      // Got it, set flag
      bDataProviderSet =
      true;
      // Override committ, this may be called repeatedly
      override protected function commitProperties():void
      // invoke ComboBox version
      super.commitProperties();
      // If value set and have dataProvider
      if (bSelectedValueSet && bDataProviderSet)
      // Set flag to false so code won't be called until selectedValue is set again
      bSelectedValueSet=
      false;
      // Loop through dataProvider
      for (var i:int=0;i<this.dataProvider.length;i++)
      // Get this item's data
      var item:String = dataProvider[i][DataGrid(listData.owner).columns[listData.columnIndex].dataField];
      // Check if is selectedValue
      if
      (item == _selectedValue)
      // Yes, set selectedIndex
      this.selectedIndex = i;
      break;
      override public function set data(value:Object):void
      super.data = value;
      selectedValue = value[DataGrid(listData.owner).columns[listData.columnIndex].dataField];
      // set for selectedValue
      public function set selectedValue(s:String):void
      // Set flag
      bSelectedValueSet =
      true;
      // Save value
      _selectedValue = s;
      // Invalidate to force commit
      invalidateProperties();
      public function get selectedValue():String
      return _selectedValue;
      How do set the the selected from combobox value back to dataGrid?
