RoboHelp X5, WebHelp
I have four hyperlinks (let's say, A, B, C, D) within my project to access external Excel spreadhsheets. A copy of the files is located in the project folder(the one on my desktop). When the project is published to the server, only two (A&B) of the four links work. To address the issue, I have to manually copy the Excel files to the server for the other links (C&D) to work.
I want to determine why RoboHelp copies some, and not all, of the Excel spreadsheets to the server. The settings for each of the hyperlinks appear to be identical, the only difference is that they're pointing to different files. Links A&B consistently work when the project is published; links C&D do not. What could be causing this issue?
Thank you,
Let's see here...
You are using X5... So you might be encountering the"Baggage Bug". Seems you have to manually edit one of the RoboHelp HTML project files for getting past that. I believe our wonderful Mr. Peter Grainge has something on his site about it. Lemme go see...
Ahhh yes, here it is.
Cheers... Rick
Hi there
You probably just need to add files C and D to the list of Baggage files in your project. That's what Baggage is for. Ensuring content you need in your project gets copied to the server.
Cheers... Rick
Hi Rick,
I tried to add those files, but no luck. The RoboHelp instructions about adding baggage files states I should be able to click "yes" to add the files, but I'm not getting that prompt (nor an error message).
Let's see here...
Cheers... Rick
