1 Reply Latest reply on Jun 6, 2009 6:31 AM by JeffryHouser
    Custom component : call a function from another custom component
    Celinio
      i call a custom component B inside another custom component A.
      That works fine.
      From custom component B, how can i call a function defined in custom component A ?
      Is is something like Parent.myFunction() ..?
      Thanks.
        • 1. Re: Custom component : call a function from another custom component
          JeffryHouser Level 4
          If I understand you, then an instance of Component B is embedded inside Component A, is that correct?
          Conceptually, a component something like this:
          <myNS:ComponentA>
            <msNSComponentB>
          </myNS:ComponentA>
          Then A has no problems calling methods /functions in Component B.  But, Component B cannot access methods / functions in Component A.
          The [best] way to do this is to launch an event from ComponentB; something like this:
          dispatchEvent(new Event('MyCustomEvent'));
          Then listen to it in Component  and perform the function:
          <myNS:ComponentA>
            <msNSComponentB myCustomEvent="DoStuffHere()">
          </myNS:ComponentA>
          If you do it this way the two components are not tightly coupled and you optimize reuse.
          But, in a pinch parent.myFunction() should work ( http://livedocs.adobe.com/flex/2/langref/mx/core/UIComponent.html#parent ).  Did you try that?  And what were the problems you had with it?
