4 Replies Latest reply on Jun 8, 2009 10:05 AM by Marc Speck
    Migration 3>4: borderStyle=none?
    Marc Speck
      I've started to test a migration of a Flex 3 app to Gumbo. I couldn't find out how to remove the border from components like e.g. mx:TextInput. The code below shows the problem:
      <mx:Application
          xmlns:fx="http://ns.adobe.com/mxml/2009"
          xmlns:mx="library://ns.adobe.com/flex/halo"
          layout="vertical"
          <mx:TextInput
              borderStyle="none"
              borderThickness="0"
              borderColor="red"
              text="A red border is visible but I expect no border."
          <mx:TextInput
              borderColor="red"
              text="A red border is visible"
      </mx:Application>
      How can I remove the border of Flex 3 components?
      Thanks for any hints,
      Marc
        • 1. Re: Migration 3>4: borderStyle=none?
          Peter deHaan Level 4
          Marc,
          I believe you may need a custom TextInput border skin to achieve the same effect with the Spark skins for the mx:TextInput control. Certain styles that were supported by the default Halo controls/containers are not as easily tweakable with the Spark skins.
          So, long story longer, here is my solution. I copied the default Spark skin for the Halo TextInput control (you can find the default skin, TextInputBorderSkin.mxml, in the <SDK_Dir>\frameworks\projects\sparkskins\src\mx\skins\spark\ folder) and made a couple minor tweaks and then saved my custom skin as CustomTextInputBorderSkin.mxml in the /src/skins/ folder of my Flex Project. Here's the revised CustomTextInputBorderSkin.mxml file:
          <!--- The Spark skin class for the border of the Halo TextInput component. -->
          <local:SparkSkinForHalo xmlns:fx="
                  xmlns:local="mx.skins.spark.*"
                  implements="mx.core.IBorder">
              <fx:Script>
                  <![CDATA[
                      import mx.core.EdgeMetrics;
                      import mx.core.IUIComponent;
                      /* Define the skin elements that should not be colorized. */
                      static private const exclusions:Array = ["background"];
                      override public function get colorizeExclusions():Array {return exclusions;}
                      /* Define the content fill items that should be colored by the "contentBackgroundColor" style. */
                      static private const contentFill:Array = ["bgFill"];
                      override public function get contentItems():Array {return contentFill};
                      /* Define the border items.*/
                      static private const borderItem:Array = [];
                      override protected function get borderItems():Array {return borderItem;}
                      static private const metrics:EdgeMetrics = new EdgeMetrics(2, 2, 2, 2);
                      public function get borderMetrics():EdgeMetrics {
                          return metrics;
                      override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void {
                          super.updateDisplayList(unscaledWidth, unscaledHeight);
                          if (parent && parent is IUIComponent && !IUIComponent(parent).enabled) {
                              alpha = 0.5;
                          } else {
                              alpha = 1;
              </fx:Script>
              <!-- fill -->
              <s:Rect id="background" left="1" right="1" top="1" bottom="1">
                  <s:fill>
                      <s:SolidColor id="bgFill" color="0xFFFFFF" />
                  </s:fill>
              </s:Rect>
          </local:SparkSkinForHalo>
          And then I specified the custom border skin by specifying the borderSkin style on the Halo TextInput control, as seen in the following example:
          <mx:Application xmlns:fx="
                  xmlns:mx="library://ns.adobe.com/flex/halo">
              <mx:TextInput
                      borderStyle="none"
                      borderThickness="0"
                      borderSkin="skins.CustomTextInputBorderSkin" />
              <mx:TextInput
                      borderColor="red"
                      text="A red border is visible" />
          </mx:Application>
          Hopefully that helps. For a lot of other great migration information and differences between Flex 3 and Flex 4 (and how to use the Halo skins in your projects), see the following article on the Flex Developer Center: http://www.adobe.com/devnet/flex/articles/flex3and4_differences.html
          Peter deHaan
          Flex SDK Team | Adobe Systems Inc
          • 2. Re: Migration 3>4: borderStyle=none?
            Marc Speck Level 1
            Thank you very much, Peter; it works as expected and I will use it.
            I wondered whether I could do it more efficiently with the spark
            TextInput. But if I understand spark styles/skins correctly, I also need
            to create a new skin. Is that correct?
            Marc
            • 3. Re: Migration 3>4: borderStyle=none?
              Correct.
              For the Spark TextInput control, I would use something like the following:
                  <s:VGroup horizontalCenter="0" verticalCenter="0">
                      <s:TextInput id="textInput"
                              skinClass="skins.CustomTextInputSkin" />
                  </s:VGroup>
              </s:Application>
              And my custom skin, /src/skins/CustomTextInputSkin.mxml, is as follows:
              <!--- The default skin class for Spark TextInput component. -->
              <s:SparkSkin xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
                    alpha.disabled="0.5">
                  <fx:Metadata>
                  <![CDATA[
                      [HostComponent("spark.components.TextInput")]
                  </fx:Metadata>
                  <fx:Script>
                      static private const exclusions:Array = ["background", "textView"];
                  </fx:Script>
                  <s:states>
                      <s:State name="normal"/>
                      <s:State name="disabled"/>
                  </s:states>
                  <!-- fill -->
                  <!--- Defines the appearance of the TextInput component's background. -->
                      <s:fill>
                      <!--- Defines the background fill color. -->
                      </s:fill>
                  </s:Rect>
                  <!-- text -->
                  <s:RichEditableText id="textView"
                            lineBreak="explicit"
                            paddingLeft="3" paddingTop="5"
                            paddingRight="3" paddingBottom="3"/>
              </s:SparkSkin>
              Peter
              • 4. Re: Migration 3>4: borderStyle=none?
                Marc Speck Level 1
                Peter, I appreciate your support!
                Thanks, Marc
