2 Replies Latest reply on Jun 7, 2009 7:33 AM by hvcardoso
    Reading from external XML source
    hvcardoso
      Hi all,
      I'm a noob at Flex but trying to learn.
      I encountered a problem that i can't seem to fix.
      I'm invoking an HTTPService like this:
      Header 1
      <mx:HTTPService
      id="searchName"
      url="
      {compexUrl}"
      result="searchHandler(event)"
      resultFormat = "
      e4x">
      <mx:request xmlns="">
      <api_key>xxxxxxxx</api_key>
      </mx:request>
      </mx:HTTPService>
      Where
      compexUrl =
      http://test/ + platform + "/" + searchTerms;
      My searchHandler is like this:
      Bindable]
      public var item:XMLList = null;
      private function searchHandler(event:ResultEvent):void{
      item=
      new XMLList(event.result);
      And the xml returned has the following aspect:
      <?xml version="1.0" encoding="UTF-8" ?>
      - <game>
      <id>20060418113640115000</id>
      - <name>
      <![CDATA[
      God Hand
      </name>
      </game>
      - <game>
      <id>2005120717012468975830</id>
      - <name>
      <![CDATA[
      God of War
      </name>
      </game>
      - <game>
      <id>20070510133243896018</id>
      - <name>
      <![CDATA[
      God of War Betrayal [mobile]
      </name>
      </game>
      - <game>
      <id>20060313151238825080</id>
      - <name>
      <![CDATA[
      God of War II
      </name>
      </game>
      - <game>
      <id>2005120717012341705322</id>
      - <name>
      <![CDATA[
      GoDai Elemental Force
      </name>
      </game>
      - <game>
      <id>2005120717012453155517</id>
      - <name>
      <![CDATA[
      Godzilla Save The Earth
      </name>
      </game>
      - <game>
      <id>20070918144248206042</id>
      - <name>
      <![CDATA[
      Godzilla: Unleashed
      </name>
      </game>
      </games>
      I want to populate my var item with all the values of the tag name but i can´t seem to figure out how?
      Can you help me please?
        • 1. Re: Reading from external XML source
          BennyBeta Level 4
          In your handler, try:
          item = event.result.game.name;
          Let me know if that helps...
          Ben Edwards
          • 2. Re: Reading from external XML source
            hvcardoso Level 1
            Hi thanks for your reply but thats not the answer, i've tried that already....
            My problem was that i had a namespace in my tags, aparently it changes the way we can access the attribute value
            <games xmlns="http://api.gamesradar.com">
            One way to deal with this namespace is to acces the variable like this:
            var ns:Namespace = new Namespace("http://api.gamesradar.com");
            item = XML(event.result).ns::game.*::name;
            After i solved this issue i stumble upon another one, i wanted to put those results in a dataGrid like this:
            <mx:DataGrid x="10" y="101" width="786" id="searchInfo" dataProvider="{item}">
            <mx:columns>
            <mx:DataGridColumn headerText="Título" dataField="name"/>
            <mx:DataGridColumn headerText="Identificador" dataField="id"/>
            </mx:columns>
            </mx:DataGrid>
            Well Flex doesn't let me do that so i followed another route.....i simply removed the namespace from my xml with this function:
            public function result(response:Object):XML{
            var xmlString:String;
            var xmlnsPattern:RegExp;
            var namespaceRemovedXML:String;
            var responseXML:XML;
            // get the XML payload
            if(ResultEvent(response).result is XMLList){
            response = ResultEvent(response).result
            as XMLList;
            else{
            as XML;
            // convert it to a string
            xmlString = response.toXMLString();
            // define the regex pattern to remove the namespaces from the string
            xmlnsPattern =
            new RegExp("xmlns[^\"]*\"[^\"]*\"", "gi");// remove the namespaces from the string representation of the XML
            namespaceRemovedXML = xmlString.replace(xmlnsPattern,
            // set the string rep. of the XML back to real XML
            responseXML =
            new XML(namespaceRemovedXML);
            return responseXML;
            Finally my handler was working and putting the values in my dataGrid by changing it to:
            [Bindable]
            item=result(event).game;
