1. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Rek Jutut Jun 7, 2009 1:26 AM (in response to Zigaa)Yep, same problem. Here are some suggestions, I haven't tried uninstalling yet.
http://forums.adobe.com/thread/442921?tstart=0
http://forums.adobe.com/thread/443272?tstart=0
-RJ-
2. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Harm Millaard Jun 7, 2009 1:54 AM (in response to Zigaa)The disk drive letter problem is a well known cause ot these issues with external drives. I don't think it is specific to XDCAM material, at least I have not had that problem with 4.1.
What you may try is before starting your project, to set the drive letter in disk management to the letter previously used in your project and then open the project. Maybe that will allow the project to start normally, maybe you need to point the project to the first offline clip and it may find the other files automatically. This is of course complicated by the many subdirectories your have, but try it. Maybe you are in luck. If that still does not work, I have no other suggestion than to go through the tedious task of selecting the correct files each and every time.
However, the other problems you mentioned seem to point to a faulty installation. Reinstalling may solve all your problems and will not destroy your project.
3. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Zigaa Jun 7, 2009 3:20 AM (in response to Harm Millaard)Hi!
Well, after 4 hours of problem-solving I figured out that the main issue was that 4.1 didn't support xdcam-ex anymore. Furthermore, when reinstalling premiere back to 4.0.1 it couldn't open a project (looks like 4.1 did something to it I guess), so final solution now was to open an auto-save project, which has just opened.
Probably there is an issue with production premium to be first installed as a trial. The solution might be to uninstall all the programs and clean the registry and install it back directly with serial number. But it takes time and I have to finish project today.
I'm really confused about Adobe's solutions in last few years; every new file/software/update they provide solves 1 old problem and gives 10 new problems.
Now it's a big mess but luckily the project is now open at least. I really do not recommend anyone to update to 4.1 because of huge problems you might have with files, at least not to do it during the work on a project.
Regards,
Ziga
4. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Harm Millaard Jun 7, 2009 3:28 AM (in response to Zigaa)In the links RJ gave you, I mentioned that a previous trial installation messes things up apparently, like you discovered.
How this got past Quality Control, I can only wonder, but it is significant that people who never used the trial version seem unaffected and people that used the trial at a certain moment, seem to have trouble.
5. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
I can open up XDCAM EX files just fine with the 4.1 update...
6. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Harm Millaard Jun 7, 2009 9:09 AM (in response to Eric Addison)So can I, but then I never used the trial version. This seems to be the distinguishing aspect.
7. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Steve4ustin Jul 14, 2009 2:03 PM (in response to Harm Millaard)Are you all using a Mac or PC?
8. Re: After updating Premiere to 4.1 - XDCAM EX error- files offline?
Harm Millaard Jul 14, 2009 2:54 PM (in response to Steve4ustin)PC.
