1 Reply Latest reply on May 14, 2017 12:05 PM by Thomas_Booth
    Accessing raw sound data tutorial doesnt work for me!!!
    sam luke
        Just tried importing the Accessing raw sound data (http://livedocs.adobe.com/flex/3/html/help.html?content=Working_with_Sound_14.html) tutorial into flex builder.  It now compiles now, altrhough I needed to include ByteArray import, but when I run it the debug window displays:
      Cannot access a property or method of a null object reference.
      If I hit continue the music plays though.  I have included the code below:
      package {
          import flash.display.Sprite;
          public class waveform_example_as extends Sprite
              public function waveform_example_as()
                  import flash.utils.ByteArray;
                  import flash.display.Graphics;
                  import flash.events.Event;
                  import flash.media.Sound;
                  import flash.media.SoundChannel;
                  import flash.media.SoundMixer;
                  import flash.net.URLRequest;
                  const PLOT_HEIGHT:int = 200;
                  const CHANNEL_LENGTH:int = 256;
                  var snd:Sound = new Sound();
                  var req:URLRequest = new URLRequest("tester.mp3");
                  snd.load(req);
                  var channel:SoundChannel;
                  channel = snd.play();
                  addEventListener(Event.ENTER_FRAME, onEnterFrame);
                  snd.addEventListener(Event.SOUND_COMPLETE, onPlaybackComplete);
                  var bytes:ByteArray = new ByteArray();
                  function onEnterFrame(event:Event):void
                      SoundMixer.computeSpectrum(bytes, false, 0);
                      var g:Graphics = this.graphics;
                      g.clear();
                      g.lineStyle(0, 0x6600CC);
                      g.beginFill(0x6600CC);
                      g.moveTo(0, PLOT_HEIGHT);
                      var n:Number = 0;
                      // left channel
                      for (var i:int = 0; i < CHANNEL_LENGTH; i++)
                          n = (bytes.readFloat() * PLOT_HEIGHT);
                          g.lineTo(i * 2, PLOT_HEIGHT - n);
                      g.lineTo(CHANNEL_LENGTH * 2, PLOT_HEIGHT);
                      g.endFill();
                      // right channel
                      g.lineStyle(0, 0xCC0066);
                      g.beginFill(0xCC0066, 0.5);
                      g.moveTo(CHANNEL_LENGTH * 2, PLOT_HEIGHT);
                      for (i = CHANNEL_LENGTH; i > 0; i--)
                      g.lineTo(0, PLOT_HEIGHT);
                      g.endFill();
                  function onPlaybackComplete(event:Event):void
                      removeEventListener(Event.ENTER_FRAME, onEnterFrame);
      Paul.
        • 1. Re: Accessing raw sound data tutorial doesnt work for me!!!
          Thomas_Booth
          //It appears the script was modified.
          //For one, there is an extra bracket. Some lines moved around.
          //Anyway, I made these changes and the script then worked fine:
          //changes are commented and marked with my initials. [tb]
          package {
              import flash.utils.ByteArray;                                         //moved the following 7 from below [tb]
              import flash.text.TextField
          //            import flash.utils.ByteArray;                                  //moved to above [tb]
          //            import flash.display.Graphics;
          //            import flash.events.Event;
          //            import flash.media.Sound;
          //            import flash.media.SoundChannel;
          //            import flash.media.SoundMixer;
          //            import flash.net.URLRequest;
          //           const PLOT_HEIGHT:int = 200;                            // these two lines moved down
          //            const CHANNEL_LENGTH:int = 256;
                      snd.load(req);
            //          snd.addEventListener(Event.SOUND_COMPLETE, onPlaybackComplete);             // commented out [tb]
                      channel.addEventListener(Event.SOUND_COMPLETE, onPlaybackComplete);         //added line [tb]
             //        var bytes:ByteArray = new ByteArray();        // commented out [tb]
            //          function onEnterFrame(event:Event):void
                        private function onEnterFrame(event:Event):void                                                      // made private [tb]
                          var bytes:ByteArray = new ByteArray();        // moved from above [tb]
                          const PLOT_HEIGHT:int = 200;                                                  // these two lines moved down from above
                          const CHANNEL_LENGTH:int = 256; // same
                          g.clear();
                          var n:Number = 0;
                          // left channel
                          g.endFill();
                          // right channel
                          g.endFill();
             //         function onPlaybackComplete(event:Event):void                                         // commented out [tb]
                      private function onPlaybackComplete(event:Event):void                               // made private [tb]
          //}        // extra bracket commented out [tb]
