This content has been marked as final.
Show 4 replies
2. Re: any command opposite of stopAllSounds()?
Newsgroup_User Aug 5, 2008 6:14 PM (in response to bhnh)bhnh,
> I'd like to code a button to alternately turn off and turn
> on the audio... button clicks, etc... in a swf.
You'll want the Sound class for that. Works great, and it's easy. :)
> stopAllSounds() does the trick for turning the audio off;
> is there an equivalent to turn the audio back on?
stopAllSounds() is good in a pinch, but like youv'e discovered it's
really nothing more than a one-way street. If you associate a Sound
instance with the main timeline, you can set its volume all the way on or
off, and that effectively gives you a global sound toggle.
http://www.quip.net/blog/2006/flash/how-to-toggle-sound-globally
http://www.quip.net/blog/2006/flash/actionscript-20/understanding-the-sound-constructor
David Stiller
Co-author, ActionScript 3.0: The Quick Answer Guide for Flash Professionals
http://tinyurl.com/2s28a5
"Luck is the residue of good design."
3. Re: any command opposite of stopAllSounds()?
bhnh Aug 6, 2008 6:03 AM (in response to Newsgroup_User)Thanks, David. I had pretty much reached that conclusion shortly after posting; wishful thinking, I guess. I actually haven't had to do much with audio since working in Flash 5. I wound up just pushing all the various Sound objects into an array, then applying setVolume() to the array. Works just fine. -
4. Re: any command opposite of stopAllSounds()?
Newsgroup_User Aug 6, 2008 6:40 AM (in response to Newsgroup_User)bhnh,
That could potentially give you individualized control over each Sound
object, which would certainly do it. Toggling sound globally means you can
do it all in one swoop. That's what I love about ActionScript ... the
flexbility! :)
Glad you found a solution.
David Stiller
Contributor, How to Cheat in Flash CS3
http://tinyurl.com/2cp6na
