1. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 7:19 AM (in response to Christian Davideck)Hue+Saturation gives you the Color blend mode, not Luminosity. Just drag a copy of the sky layer above the ray and set it to Color. Why Pin Light though? try Linear Light
2. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 7:30 AM (in response to Zeno Bokor)Thanks for showing up.
My OP says: "Now, what I'd like to do with the ray, is getting the hue+saturation from the sky layer, in other words apply a luminosity blending [to the ray layer]." that's correct. If you set the ray layer to luminosity, you get hue+saturation from the background layer.
No, no duplicating of layers. I want to avoid to increase file size.
it's just an example. Pin light/linear light doesn't change anything about my question in theory. The point is, how can I apply 2 blending modes ?
3. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 7:48 AM (in response to Christian Davideck)I'd say that you're over complicating things. You want the color of the sky on the ray so if you don't want to increase the size, make a Smart Object out of the sky layer, copy it above the ray and set it to Color
4. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 7:58 AM (in response to Zeno Bokor)No, duplicating Smart Objects also increases file size. Besides, this is just a simplified example. In reality the sky layer is a compound of dozens of layers, clipping masks, etc.
I'd just like to restrict the pin lighting to it's luminosity aspect (i.e. apply pin lighting AND luminosity) and I'm looking for an elegant solution, without duplicating raster layers, etc.
5. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 8:17 AM (in response to Christian Davideck)I'm looking for an elegant solution, without duplicating raster layers, etc.
Yes your right, its hardly ever necessary to duplicate raster layers - the same effects can always be achieved with blend modes and adjustment layers
The problem is Christian, the description of your problem makes it very difficault to understand EXACTLY what you are trying to do, and you are misusing terms which doesn't help. A merged layer using your pin light blend - blended using Luminosity is the solution to how I interpret that comment, but cant be sure.
There is always a solution to these things - as I said you solution may be a simple case of recolorising your results using TARGETED range adjustment layers. Also properly structuring of your file (using layer groups, and understanding how these can be individually color controlled, and blended) - may be the key.
6. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 8:15 AM (in response to Christian Davideck)weird, for some reason i thought that copying SOs doesn't change file size as the copy would be just a reference point toward the original SO
The other way around this would be to set the ray to Pin Light, Ctrl+Alt+Shift+E to merge everything to a new layer, delete the ray and set the merged copy to Luminosity
7. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 8:21 AM (in response to Zeno Bokor)Every copy of an Smart Object you make (instance or actual duplicate) also duplicates the PREVIEW pixels held in the master file.
8. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 8:29 AM (in response to Reynolds (Mark))so then why does it make the file on the disk bigger? does it also preview the file size on disk?
Adjustment layers can't be used as dummy layers for the Hue/Sat/Color/Lum blend modes, you need to duplicate pixel layers, no working around that
9. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 8:59 AM (in response to Zeno Bokor)why does it make the file on the disk bigger?
Because its duplicating pixels. Remember each one of the instances of the Smart Object can have a different scaling and transform. I'll repeat myself since you didnt seem to listen first time - "also duplicates the PREVIEW pixels held in the master file."
Your actually completely wrong on this one Zeno. As a very simple example, take a curve and apply Multiply blend to it. Then duplicate the pixels and apply a Multiply blend. Same result, smaller file. While there are many of tutorials all over the place telling people to duplicate pixels to do these things, (easier for people to conceptualise perhaps, but more likely to do with lack of knowledge on the part of those writing the tutorials) - duplicate pixels extremely rarely have an advantage over non-file heavy methods.
10. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 9:00 AM (in response to Reynolds (Mark))and i'll repeat myself, it doesn't make any sense, it shouldn't do that The way i see it, when you embed a file as a SO it creates a file inside your .psd. When you duplicate the smart object it shouldn't take up twice the memory, it should reference the pixels from the first SO and only require memory/disk space for what you add to the second SO (layer styles/filters/etc).
You know, i had this image of Smart Objects that they work something like Adjustment layers in that it only takes a couple of bytes to tell it to reference the original image. I don't know where i got it from but i always assumed that it was correct so i never bothered to put it to the test, what a let down
11. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 9:02 AM (in response to Reynolds (Mark))I didn't say anything about Multiply, i specifically said that this only happens with the Hue/Saturation/Color/Luminosity blend modes, try to do what he asks with adjustment layers, see if it works
12. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 9:14 AM (in response to Zeno Bokor)Works the same with any mode Zeno, try it.
13. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 9:15 AM (in response to Reynolds (Mark))I'm looking for an elegant solution, without duplicating raster layers, etc.
Mark, I'm glad that you see it the same way.
Going back from smart objects to the original question ... what terms am I misusing? I don't hink so.
I'm not sure what you don't understand:
As I said above:
It would then look like this (check the .psd document, if you're unclear about the layer configuration):
No, I know there are ways to get this screen output (adjustment layers, etc.) but that's not the point ...
14. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 9:25 AM (in response to Christian Davideck)Just to make it clear: I don't need this specific image and this specific outcome (which could be achieved with adjustment layers, too). I'd simply like to find a way to "combine" (or however you wanna call it) two blending modes ...
15. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 9:24 AM (in response to Zeno Bokor)First of all Zeno…
When photoshop opens the file, it needs a RASTERISED VERSION held in the master document. If it were to use the method you have proposed it would slow things down impossibly. Every time you open a file, every movement, adjustment it would have to render on the fly. These things can become quite complex - imagine a file with 200 instances of the same Smart Object. Would be impossible. I used to think the same as you when Smart objects were first introduced.
16. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 9:27 AM (in response to Reynolds (Mark))Folks, I don't mean to be rude or anything, because I honestly appreciate a lot that you are trying to help me! ... but would you mind to continue a discussion about smart objects in another thread (there are quite a lot about smart objects), because it doesn't have anything to do with this issue ... I'd be thankful indeed
17. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 9:48 AM (in response to Reynolds (Mark))as i said, i didn't really think it through, i was just presuming that it worked like that, don't overanalyze it
So then back to the question at hand, how would you use adjustment layers to achieve the effect that he wants? i for one couldn't figure it out
18. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 10:01 AM (in response to Zeno Bokor)thank you guys.
It's not difficult to use adjustment layers for this example. Just add a hue/saturation adjustment layer, or a curves layer or whatever you like and clip it to the ray layer ... but that's really not the point. The question is not how to find workarounds that just happen to look like the image above. It's rather a matter of principle ... an enhanced use of blending modes, if you will.
19. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 10:28 AM (in response to Christian Davideck)Its not possible to directly combine two blend modes using a simple process. Blend modes use specific math, and as a result combining them is not a straightforward, the order in which they are applied for one thing makes this impossible. You have to analyse visually what you want. If you can achieve pretty well the same visual result using lets say Hard Light with advanced blending why not do it that way?
20. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 10:45 AM (in response to Reynolds (Mark))Reynolds (Mark) wrote:
I know about the maths. But the example I'm giving you here is mathematically possible: Apply a pin light blending but restrict it's outcome to luminosity changes ... (it's a bit like adding a curves layer and set it to luminosity, to restrict the outcome to luminosity changes, if you understand the analogy).
When you say "advanced blending" are you referring to "blend if"?
I already answered this. Because it may happen to give a similar outcome for this example. But I don't care about this specific image.
I want to be able to restrict blending modes to hue, saturation, luminosity or color (because I'm not sure as to whether this would work with other modes, too. For example, you can't apply "darker color" AND "lighter color", this is mathematically impossible).
21. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 11:08 AM (in response to Christian Davideck)Ok, thinking this through again, what you are asking is a very interesting challenge Christian: A non destructive way to achieve the same result as a applying two modes to a layer in a particular order.
I dont think this is possible at the moment for the reasons I've said. Maybe someone, (one of the engineers maybe?) could tell me if I'm wrong. The ways that have been pointed out to you by Zeno, accurately achieve the same result, granted in a non editable way. In addition Calculations could be used. An arrangement of layers? At the moment I'm not so sure this is possible - mainly because the blend mode math is fixed and not editable in any way. Grouping, group modes and layer structures do not help here.
22. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 11:30 AM (in response to Reynolds (Mark))Reynolds (Mark) wrote:
You got it. We're on the same page now.
Maybe technically it's not possible (although I'm sure that there must be a way to do it), but mathematically it IS (I hope you see, why).
Yes, in a non-editable way, and by duplicating raster layers, increasing file size, etc. And most importantly: it's not quite the same thing as your statemetn in bold above.
Yes, I was also thinking of grouping the layer and setting the group blend to luminosity .... or clipping the ray layer to a 50%gray layer with pin light and set the ray layer to luminosity (with or without "blend clipped layers as a group") ... just guessing around, but obviously all those things don't work ... but I'm sure, there's a trick if you combine the right techniques ...
... maybe Chris will show up here, as he knows a lot about the blending modes ... :hope:
23. Re: How to create a "double blending" ?
Reynolds (Mark) Jun 8, 2009 11:40 AM (in response to Christian Davideck)... but I'm sure, there's a trick if you combine the right techniques ...
I'm not so sure, if there were a trick for this type of thing, pretty convinced I would have heard of it. I remember trying to find the same solution, back in the days of 6 or 7.
Zeno's Smart Object solution was also a very good non-destructive recommendation When it comes to issues like file sizes, then things have moved on.
24. Re: How to create a "double blending" ?
Zeno Bokor Jun 8, 2009 11:42 AM (in response to Reynolds (Mark))knockouts also don't help. Another option would be to just fake it, add a Color/Gradient Overlay set to Color to the ray that has the same color as the sky
25. Re: How to create a "double blending" ?
Christian Davideck Jun 8, 2009 4:23 PM (in response to Zeno Bokor)Zeno Bokor wrote:
thanks for searching though (knockout, etc.) ...
and as for your suggestion, well as I said, it's an example only. Imagine there were flowers instead of the sky ...
26. Re: How to create a "double blending" ?
George Austin Jun 8, 2009 11:07 PM (in response to Christian Davideck)One thing you've heard from me before on a recent post by Christian: None of the four blend modes Hue, Saturation, Color, and Luminosity preserves the saturatiion of either the base color or the blend color. Repeat NONE. Zilch. Yes, you can preserve base hue and base luminosity via the saturation blend mode, base luminosity and blend hue via the hue blend mode or color blend mode, and base hue and blend luminosity via the luminosity blend mode. But SATURATION of neither the base nor blend color gets preserved by any of these blends despite what Photoshop Help says to the contrary. So you're not going to get hue and saturation from the sky by applying the luminosity blend.
It's also an exercise in futility to attempt combining Pin Light (an RGB blend) with Luminosity (an HSB blend) into a single blend action. Their different color spaces require separate mathematics.
