3 Replies Latest reply on Jun 9, 2009 7:28 AM by the_wine_snob
    Crackle in Audio on Burned DVD
    hnester
      It sounds fine on my laptop. I have a horrible old TV. I played it over a sound system and they had a sound board. The audio was hot. What can cause crackled audio? Here is what I've done:
      1) Created 4 slide shows w/ transitions and each with different MP3 songs from Amazon downloads.
      2) Outputed to DV AVI.
      3) Used Windows DVD maker to create a demo DVD w/ all 4 slide shows and a menu
      The guy I was meeting w/ suggested I turn the volume down on the song to record it.  The volume is at 4.6 db...I have not changed this. The clip fades in and fades out...I set those fades. How do I set the volume for the rest of the clip?
      I have a PC with Vista (32 bit), 3 Gig of RAM, Core2 Duo Processor 2.10 Ghz,I think the audio card information you need is that it is Realtek HD Audio, The graphics is Nvidia, right now I have 27 Gig hard drive free but I think that day I had 34 Gig, Oh, and I think I've turned windows Aero off along w/ all the other recommendations.
      How do I troubleshoot this if I have no sound board and it sounds fine to me?
      Hope I've given relevant information!
      Holly
        • 1. Re: Crackle in Audio on Burned DVD
          the_wine_snob Level 9
          "Crackle" in Audio is almost always due to clipping of the Audio.
          In PE, and with the Audio Mixer (Window>Audio Mixer), what are your levels? I'd guess that your source Audio is too "hot," and might well benefit from some pre-processing, prior to Import into PE. You mention MP3's, but I'm not sure what processing you might have applied before inclusion in PE. Can you list your steps?
          • 2. Re: Crackle in Audio on Burned DVD
            hnester Level 1
            Hunt,
            The audio levels....is this what you mean?:
            ...yes I just followed your menu path and it was the same as the clip volume 4.6 db.
            All other values were 0.
            I didn't do any audio processing. Just dropped it into PE. Maybe that is my problem? Yes, the guy w/ the sound board showed me it was hot. Is there a way to determine this if you don't have a sound board?
            Holly
            • 3. Re: Crackle in Audio on Burned DVD
              If that is a + 4.6db, then you are getting a ton of clipping of the Audio. Digital Audio should be at 0db max.
              Unfortunately, if the source files are this "hot," then the clipping has already occurred. MP3 is also a highly compressed format, so all that went into it, when processed originally (before you got the files) has already caused a problem.
              You might have some luck using a program like the freeware Audacity to re-process your files, and limiting them to -3db (though a digital Audio file can be up to 0db, the -3db gives some headroom, and allows for spikes. I'd look into adding some EQ and also try Normalizing to -3db. I cannot recall which plug-ins come with Audacity, but would suspect that one could add all sorts of VST's to provide you with processing within the program. Might have to Google for VST's and install them. Most will be free and some available for a nominal fee. You might be able to get a usable source file, but remember that the damage has already been done with the original's processing and then the MP3 compression. Can you locate a better source file elsewhere? Personally, I'd look to getting the material in CD-quality 44.1KHz 16-bit form, and ripping the CD to 48KHz 16-bit Audio (PCM WAV) for use in PE. I am not a fan of MP3 compression, even when done right - just too much of the original source is lost by my ears.
