5 Replies Latest reply on Nov 11, 2010 5:22 AM by KapilArora021983
    How to Convert xmlListCollection to ArrayCollection
    Raghuvasa
      Hi All,
        i have XmlListCollection like this
               <mx:XMLListCollection id="msgList" source="{usersXML.item.name}" />
      i need to convert this xmlListCollection to ArrayCollection.
      is there any chance to do that.
      Can any one help me.
      Raghu.
        • 1. Re: How to Convert xmlListCollection to ArrayCollection
          Flex harUI Adobe Employee
          Other than speed, there usually isn't a requirement to do such a conversion when working with Flex controls.  Flex doesn't have any easy way of doing this.  There may be some libraries out there, but it might be just as easy to write a loop and copy the XML data into value objects.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: How to Convert xmlListCollection to ArrayCollection
            AICC
            Any word on this problem:
            Is this possible with FLEX 4?
            ERROR I GET ....or is similar
            Description Resource Path Location Type
            1067: Implicit coercion of a value of type XMLList to an unrelated type XML. Main.mxml /SafDatabase/src line 62 Flex Problem
            1067: Implicit coercion of a value of type XMLList to an unrelated type mx.collections:ArrayList. Main.mxml /SafDatabase/src line 64 Flex Problem
            thanks in advance.
            Doug Lubey of Louisiana
            www.douglubey.com
            • 3. Re: How to Convert xmlListCollection to ArrayCollection
              BhaskerChari Level 4
              Hi Raghuvasa,
              Check the below code which converts XmlListCollection to an ArrayCollection by making use of SimpleXMLDecoder class..
              <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" creationComplete="init();" layout="absolute">
              <mx:Script>
                <![CDATA[
                 import mx.collections.ArrayCollection;
                 import mx.rpc.xml.SimpleXMLDecoder;
                 private var acAllNodes:ArrayCollection;
                 private var acOpenNodes:ArrayCollection;
                 private function init():void
                  convertXmlListToArrayCollection();
                 private function convertXmlListToArrayCollection():void
                  var strXML:String = dpNodes.toXMLString();
                  strXML = "<root>" + strXML + "</root>";
                  var xml:XML = new XML(strXML);
                  var xmlDoc:XMLDocument = new XMLDocument(xml);
                  var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
                  var resultObj:Object = decoder.decodeXML(xmlDoc);
                  acAllNodes = new ArrayCollection();
                  if(resultObj.root.hasOwnProperty("parentNode"))
                   if(resultObj.root.parentNode is ArrayCollection)
                    acAllNodes = resultObj.root.parentNode;
                   else if(resultObj.root.parentNode is Object)
                    acAllNodes.addItem(resultObj.root.parentNode);
              </mx:Script>
              <mx:XMLListCollection id="dpNodes">
                      <mx:source>
                          <mx:XMLList>
                              <parentNode ID="2" Title="Hand Tools" NodeType="root" isBranch="true" isOpen="true">
                    <equipment ID="0" Title="[Add New Category]" NodeType="subcat" isBranch="false" ParentID="2" isOpen="true"/>
                    <equipment ID="0" Title="[Add New Item]" NodeType="subcat" isBranch="false" ParentID="2" isOpen="false"/>
                  </parentNode>
                  <parentNode ID="4" Title="Power Tools" NodeType="root" isBranch="true" isOpen="false">
                    <equipment ID="10" Title="Hydraulics" NodeType="subcat" isBranch="true" ParentID="4" isOpen="false">
                      <item ID="8" Title="Tool 1" NodeType="item" isBranch="false"/>
                      <item ID="9" Title="Tool 2" NodeType="item" isBranch="false"/>
                      <item ID="10" Title="Tool 3" NodeType="item" isBranch="false"/>
                      <item ID="11" Title="Tool 4" NodeType="item" isBranch="false"/>
                      <item ID="12" Title="Tool 5" NodeType="item" isBranch="false"/>
                      <equipment ID="0" Title="[Add New Category]" NodeType="subcat" isBranch="false" ParentID="10" isOpen="false"/>
                      <equipment ID="0" Title="[Add New Item]" NodeType="subcat" isBranch="false" ParentID="10" isOpen="false"/>
                    </equipment>
                    <equipment ID="11" Title="Electric, Cordless" NodeType="subcat" isBranch="true" ParentID="4" isOpen="false">
                      <item ID="28" Title="9v screwdriver" NodeType="item" isBranch="false"/>
                      <equipment ID="12" Title="12V" NodeType="subcat" isBranch="true" ParentID="11" isOpen="false">
                        <equipment ID="0" Title="[Add New Category]" NodeType="subcat" isBranch="false" ParentID="12" isOpen="false"/>
                        <equipment ID="0" Title="[Add New Item]" NodeType="subcat" isBranch="false" ParentID="12" isOpen="false"/>
                      </equipment>
                      <equipment ID="13" Title="18V" NodeType="subcat" isBranch="true" ParentID="11" isOpen="false">
                        <equipment ID="0" Title="[Add New Category]" NodeType="subcat" isBranch="false" ParentID="13" isOpen="false"/>
                        <equipment ID="0" Title="[Add New Item]" NodeType="subcat" isBranch="false" ParentID="13" isOpen="false"/>
                      </equipment>
                      <equipment ID="0" Title="[Add New Category]" NodeType="subcat" isBranch="false" ParentID="11" isOpen="false"/>
                      <equipment ID="0" Title="[Add New Item]" NodeType="subcat" isBranch="false" ParentID="11" isOpen="false"/>
                    </equipment>
                  </parentNode>
                          </mx:XMLList>
                      </mx:source>
                  </mx:XMLListCollection>
              </mx:Application>
              If this post answers your question or helps, please kindly mark it as such.
              Bhasker Chari
              • 4. Re: How to Convert xmlListCollection to ArrayCollection
                artaxerxe123
                Very good answer BhaskerChari. It helped me also!
