0 Replies Latest reply on Jun 8, 2009 10:00 PM by LJ6m3gu9
    What is the Equivalent Non-Deprecated Code?
    LJ6m3gu9
      I have tried the obvious change to <mx:horizontalAxisRenderers> with not exactly the same presentation as before.  So, what are the exact steps necessary to recode the red lines, below, such that same result occurs?  Thank you.
      <mx:VBox xmlns:mx="http://www.adobe.com/2006/mxml" xmlns:flexlib="http://code.google.com/p/flexlib/">
      <mx:HBox width="100%" height="100%">
           <mx:CartesianChart id="bigChart"
            gutterLeft="50" gutterRight="50" gutterBottom="60" gutterTop="60"
            showDataTips="true"
            dataProvider="{mainData}" >
               <mx:horizontalAxis>
                <mx:CategoryAxis categoryField="x"/>
               </mx:horizontalAxis>
               <mx:horizontalAxisRenderer>
                <mx:AxisRenderer placement="{horizontalAxisPlacement}" />
               </mx:horizontalAxisRenderer>
               <mx:verticalAxis>
                <mx:LinearAxis maximum="{maxVAxis}" />
               </mx:verticalAxis>
               <mx:verticalAxisRenderer>
                <mx:AxisRenderer placement="{verticalAxisPlacement}"  />
               </mx:verticalAxisRenderer>
               <mx:series>
                   <mx:AreaSeries name="y" yField="y"
                    areaFill="{areaColor}"  areaStroke="{areaStroke}" />
               </mx:series>
               <mx:annotationElements>
                   <mx:Canvas width="100%" height="100%"
                    buttonMode="true" mouseDown="setMouseDown(bigChart)" />
               </mx:annotationElements>
           </mx:CartesianChart>
          </mx:HBox>
          <mx:Spacer height="{gapBetweenCharts}" />
          <mx:VBox verticalGap="0" width="100%" verticalScrollPolicy="off" horizontalAlign="left" >
              <mx:CartesianChart id="smallChart"
               width="100%" height="100"
               dataProvider="{chartData}"
               showDataTips="true" >
                  <mx:horizontalAxis>
                   <mx:AxisRenderer visible="false" />
                  <mx:verticalAxis>
                   <mx:LinearAxis />
                  </mx:verticalAxis>
                  <mx:series>
                       areaStroke="{areaStroke}" areaFill="{areaColor}" />
                  </mx:series>
                      <mx:HDividedBox id="overlayCanvas" width="100%" alpha="1" dividerAffordance="5" liveDragging="true" horizontalGap="10" verticalGap="0" horizontalScrollPolicy="off"
                                      dividerDrag="updateBoundariesFromDivider(event)" dividerSkin="{blankDividerClass}"
                                      mouseOver="overlayCanvas.setStyle('dividerSkin', dividerClass);" mouseOut="overlayCanvas.setStyle('dividerSkin', blankDividerClass);">
                          <mx:Canvas id="leftBox" height="100%"
                                     width="{(overlayCanvas.width / chartData.length) * leftBoundary}"
                                     backgroundAlpha="0.4" backgroundColor="#EEEEEE" borderThickness="1" borderColor="#999999" borderStyle="solid" />
                          <mx:Canvas id="visibleBox" width="100%" height="100%" buttonMode="true" mouseDown="setMouseDown(smallChart)" />
                          <mx:Canvas id="rightBox" height="100%"
                                     width="{(overlayCanvas.width / chartData.length) * (chartData.length - rightBoundary)}"
                                     backgroundAlpha="0.4" backgroundColor="#EEEEEE" borderThickness="1" borderColor="#999999" borderStyle="solid"/>
                      </mx:HDividedBox>
              <mx:Spacer height="-40" />
              <mx:HBox horizontalGap="0">
               <mx:Spacer width="24" />
               <flexlib:HSlider id="slider" width="{overlayCanvas.width + 12}"  height="25"
                              trackHighlightSkin="flexlib.skins.SliderThumbHighlightSkin"
                              trackSkin="EmptySkin"
                              allowTrackClick="true" allowThumbOverlap="false"
                              liveDragging="true" change="updateBoundariesFromSlider()"
                              showDataTip="true" dataTipPlacement="bottom" dataTipOffset="3"
                              showTrackHighlight="true"
                              thumbCount="2" snapInterval="1"
                              values="{[leftBoundary, rightBoundary]}"
                              minimum="0" maximum="{chartData.length - 1}"
              </mx:HBox>
               <mx:Spacer height="{gapAtBottom}" />
          </mx:VBox>
          <mx:Script>
              <![CDATA[
               import mx.rpc.events.ResultEvent;
               import mx.rpc.http.HTTPService;
                  import mx.managers.SystemManager;
                  import mx.events.ResizeEvent;
                  import mx.graphics.Stroke;
                  import mx.graphics.SolidColor;
                  import mx.collections.ArrayCollection;
                  import mx.events.DividerEvent;
                  [Embed(source="img/divider.png")] [Bindable] public var dividerClass:Class;
                  [Embed(source="img/blank.png")] [Bindable] public var blankDividerClass:Class;
                  private var DATA_LENGTH:Number = 500;
                  private var LEFT_START:Number = 150;
                  private var RIGHT_START:Number = 250;
                  [Bindable] public var chartData:ArrayCollection;
                  [Bindable] public var mainData:ArrayCollection;
                  [Bindable] private var leftBoundary:Number;
                  [Bindable] private var rightBoundary:Number;
                  private var staticLeftBoundary:Number;
                  private var staticRightBoundary:Number;
                  public var smallDrag:Boolean = false;
                  public var bigDrag:Boolean = false;
                  public var mouseXRef:Number;
                  [Bindable]
                  public var maxVAxis:Number = 100;
                  /* Some customizable colors for the ara fill and stroke. */
                  [Bindable]
                  public var areaColor:SolidColor = new SolidColor(0x0033CC, 0.5);
                  [Bindable]
                  public var areaStroke:Stroke = new Stroke(0x0033CC, 2);
                  /* Two spacer heights, these are used to determine the layout of the
                   * small chart versus the big chart.
                  [Bindable]
                  public var gapBetweenCharts:Number = 0;
                  [Bindable]
                  public var gapAtBottom:Number = 0;
                  /* Some customizable variables to affect the layout of the axes */
                  [Bindable]
                  public var horizontalAxisPlacement:String = "top";
                  [Bindable]
                  public var verticalAxisPlacement:String = "left";
                  public function loadData(url:String):void {
                   var req:HTTPService = new HTTPService();
                   req.resultFormat = "text";
                   req.url = url;
                   req.addEventListener(ResultEvent.RESULT, parseData);
                   req.send();
                   * We're loading a CSV file, so all our data points are separated by newlines.
                   * We split the result, the loop over and create the dataprovider for the chart.
                   * The y field is the data point value, the x field is the index of the data point.
                  private function parseData(event:ResultEvent):void {
                   var data:String = event.result as String;
                   var array:Array = data.split("\r");
                   var ac:ArrayCollection = new ArrayCollection();
                   for(var i:int=0; i<array.length; i++) {
                    ac.addItem({x:i, y:array[i]});
                   chartData = ac;
                   mainData = new ArrayCollection(chartData.source);
                   leftBoundary = LEFT_START;
                      rightBoundary = RIGHT_START;
                      updateBoundariesFromSlider();
                  private function updateBoundariesFromSlider():void
                      leftBoundary = slider.values[0];
                      rightBoundary = slider.values[1];
                      updateMainData();
                  private function updateBoundariesFromDivider(event:DividerEvent):void
                      leftBoundary = Math.abs(HDividedBox(event.target).getChildAt(0).width / (event.target.width / chartData.length));
                      rightBoundary = Math.abs(chartData.length - (HDividedBox(event.target).getChildAt(2).width / (event.target.width / chartData.length)));
                      updateMainData();
                  private function updateMainData():void
                      mainData.source = chartData.source.slice(leftBoundary, rightBoundary)
                  private function setMouseDown(theChart:CartesianChart):void
                      mouseXRef = this.mouseX;
                      staticLeftBoundary = leftBoundary;
                      staticRightBoundary = rightBoundary;
                      if(theChart == bigChart) bigDrag = true;
                      if(theChart == smallChart) smallDrag = true;
                      this.systemManager.addEventListener(MouseEvent.MOUSE_MOVE, moveChart);
                      this.systemManager.addEventListener(MouseEvent.MOUSE_UP, stopDragging);
                  private function stopDragging(event:MouseEvent):void
                      smallDrag = false;
                      bigDrag = false;
                      this.systemManager.removeEventListener(MouseEvent.MOUSE_MOVE, moveChart);
                      this.systemManager.removeEventListener(MouseEvent.MOUSE_UP, stopDragging);
                  private function moveChart(event:MouseEvent):void
                      if(bigDrag)
                          leftBoundary = staticLeftBoundary + (mouseXRef - this.mouseX) / (bigChart.width / mainData.length);
                          rightBoundary = staticRightBoundary + (mouseXRef - this.mouseX) / (bigChart.width / mainData.length);
                      else if(smallDrag)
                          leftBoundary = staticLeftBoundary - (mouseXRef - this.mouseX) / (smallChart.width / chartData.length);
                          rightBoundary = staticRightBoundary - (mouseXRef - this.mouseX) / (smallChart.width / chartData.length);
          </mx:Script>
      </mx:VBox>
