3 Replies Latest reply on Jun 9, 2009 5:03 AM by penyfai
    Applescript to add multiple assets to INDL
    penyfai Level 1
      Hi
      I'm having problems writing an applescript that will take an item (or all items) on a page and add it/them to the Indesign library. I can get all graphic elements associated to an advert ID (eg: advert name 12345678, has 6 associated graphics named 12345678_*) and I can place them onto the page. I cannot then add these to the the library that has been created by the same script (12345678_library.indl).
      I've tried (snippet):
      set graphiclist to ""
      set graphicpath to (standardgraphicpath & lastdigits & ":")
      set graphicnumber to (count of files in folder graphicpath)
      set graphiclist to (name of every file in folder graphicpath where name contains adCID) as list
      repeat with i from 1 to number of items in graphiclist
      set graphicname to item i of graphiclist
      set fullgraphic to (graphicpath & graphicname)
      tell application "Adobe InDesign CS3"
      try
      set mypage to page 1 of spread 1 of active document
      tell mypage
      set placedgraphic to place fullgraphic
      tell document 1
      set activegraphic to item 1 of mypage
      set addgraphic to store graphiclib using activegraphic
      end tell
      end tell
      on error
      activate
      display dialog ("Had a problem with graphic " & graphicname)
      end try
      end tell
      --tell lib to get graphic and add to library
      end repeat
      I contstantly get a the error "Had a problem with graphic " & graphicname after the pictures are placed on the page
      I don't mind if we can make use of "Add items of page 1 as separate objects" as I can place all images successfully.
      Can someone please tell me where I'm going wrong - I think my head is about to explode!
      Thanks in anticipation
        • 1. Re: Applescript to add multiple assets to INDL
          sstanleyau Level 4
          You're trying to use the "store" command inside a "tell document" block -- that block is unnecessary anyway, so remove it and try again.
          Shane Stanley <sstanley@myriad-com.com.au>
          AppleScript Pro Sessions <http://scriptingmatters.com/aspro>
          • 2. Re: Applescript to add multiple assets to INDL
            penyfai Level 1
            Thanks for that Shane, but for some reason the script is reporting that it can't get item 1 of page 1 of spread 1.
            I can't see why not, there's only one item on the page, plus the library panel that is open.
            Have I moved the store line to the wrong place?
            try
            tell mypage
            end tell
            on error
            activate
            end try
            set activegraphic to item 1 of page 1 of spread 1
            end tell
            end repeat
            • 3. Re: Applescript to add multiple assets to INDL
              penyfai Level 1
              HI again Shane
              I got to think about the item issue. I was picking activegraphic as item 1 etc.
              I has now worked by simply using placedgraphic, as it holds all of the properties for the asset I needed to store.
              But thanks for the help, I was going further and further down a blind alley, but you turned me around and showed me the light.
              Cheers
              Andrew
