6 Replies Latest reply on Jun 9, 2009 2:05 PM by Flex harUI
    List itemRenderer problem
    DigitalSpeciaist Level 1
      I am testing a very simple itemRenderer for the List control, the problem is that the itemRenderer set data method is being called three times, instead of one. I know this because I am tracing the data value when the set data metod is called. Why is this happening? See below.
      [Bindable]
      private var simpleArray:Array = new Array("one", "two", "three", "four","five");
      [Bindable]
      private var theData:ArrayCollection = new ArrayCollection (simpleArray);
      <mx:List itemRenderer="com.myTestClasses.renderers.testDataAmount" dataProvider="{theData}"/>
      package com.myTestClasses.renderers
      import mx.containers.HBox;
          import mx.controls.Label;
          import mx.core.IDataRenderer;
          public class testDataAmount extends HBox
              private var nameLabel:Label;
              private var ageLabel:Label;
              private var appearanceLabel:Label;
              private var _data:Object;
              public function testDataAmount() {
                  super();
              override public function get data():Object {
                  if(_data != null) {
                      return _data;
                  return null;
              override public function set data(value:Object):void {
              super.data = value;
      trace ("value test: " + value);
                  _data = value;
      //  This is the trace statement output
      value test: one
      value test: one
      value test: two
      value test: three
      value test: four
      value test: five
      value test: one
      value test: two
      value test: three
      value test: four
      value test: five
        • 1. Re: List itemRenderer problem
          Flex harUI Adobe Employee
          Probably measuring items to determine the size.  You cannot count on how often the data setter will be called.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: List itemRenderer problem
            JeffryHouser Level 4
            I've seen this happen during the initial setup of a component.  However, I would not expect it to occur once the component is initialized, not as you scroll through the list of items.  I was unclear if you had
            Add in an "onDataChange" handler.  IT may provide some more insight.  [no guarantees though]
            To figure out why, you'd have to step through the framework source.
            • 3. Re: List itemRenderer problem
              The reason I did that test is actually because of my real problem:
              The data property in the itemRenderer is not being reset, it is storing the previous value and concantenating the new values each time.
              Am I missing a step? Do I have to reset or invalidate the data value in the itemRenderer on each call, for it to stop storing the previously assigned value?
              Thanks for any help, Mates.
              • 4. Re: List itemRenderer problem
                What do you mean by concatenating?  In what you see or when you actually inspect the data property?
                Alex Harui
                Flex SDK Developer
                Adobe Systems Inc.
                • 5. Re: List itemRenderer problem
                  It seems like I have to purge the ItemRenderers using the following protected method:
                  purgeItemRenderers();
                  That solved half the problem (where the data property was not being reset). So the data property is only being set once. This is good
                  The last bit to resolve is: my entire itemRenderer is being repeated but without the content, since the content has been purged, as per the code above.
                  Now, how do I clear out the itemRenderer so it is only rendered once each time? I am wondering how to use the invalidateDisplayList and if that will solve the problem.
                  Thanks.
                  • 6. Re: List itemRenderer problem
                    Purging shouldn't be necessary.  Your renderers shouldn't have concatenating behavior unless you are handling some corner case.  The major feature of List is that it virtualizes renderers.  You can have 100,000 rows of data but if only 7 rows are visible on about 7 (not exactly 7) renderers exist and are recycled to view different rows as you scroll.  The memory required for 100,000 renderers is prohibitive.  Because renderers are recycled, the data setter is fired often.  Purging would cause performance problems because new renderers will need to be created and added to the display list.
                    If you don't need virtualization, consider Repeater and VBox.
                    Alex Harui
                    Flex SDK Developer
                    Adobe Systems Inc.
