0 Replies Latest reply on Jun 9, 2009 12:04 PM by Clifford Meece
    Accessing Programmatic skin variables
    Clifford Meece
      Hi, I have a button with a custom programmatic skin set in css.  The Skin draws a simple circle with a '+' inside.  This works fine.  The problem is positioning my button component.
      The button can appear in a fe places in my app, and I can't always get it to line up the way I want.  For example, I would like to place it in a HBox, but then I can't quite get the vertical alignment correct, and if I get it right, it is then wrong when the button with the same skin appears later in a different hbox component with different characteristics.
      I figure I have two possible solutions but I don't know how to do either:
      1) let HBox lay out the component and then move it slightly into place.  Is this possible?  Can I adjust the automatic layout without getting rid of it entirely?
      2) My Programmatic skin has some public variables that help it to draw itself.  Is there a way to access this skin via a component that has it?  If so I can then manually set the skin properties for some of the components to get a customized drawing that aligns properly.
      This is what I have so far:
      in my package definition:
      // The following meta tags allow me to grab the values defined in the
      // CSS definitions for each respective 'named' skin type.
      [Style (name="plusButtonSkin", type="Class")]
      in my custom component definition:
      // instance variables corresponding to the metatags above
      // which in turn match to the css named skin types
      protected var addButtonSkin:Class;
      And here I am creating children in my component:
      // Add the left button
      leftAddButton = new Button();
      leftAddButton.width=10;
      leftAddButton.height=10;
      // set my instance variable to the css variable definition
      addButtonSkin = getStyle("addButtonSkin");
      // set the styles
      leftAddButton.setStyle("upSkin",addButtonSkin);
      leftAddButton.setStyle("downSkin",addButtonSkin);
      leftAddButton.setStyle("overSkin",addButtonSkin);
      leftAddButton.addEventListener(MouseEvent.MOUSE_DOWN,startNewNode);
      this.addChild(leftAddButton);
      So after adding the 'leftAddButton', the vertical alignment is off, so I need to either do something 'like'
      leftAddButton.moveToCorrectVerticalAlignment
      or
      addButtonSkin.somePropertyToHelpMeDraw=something
      Thanks for any advice,
      Cliff
