13 Replies Latest reply on Jun 16, 2009 7:30 AM by philippe.sabourin
    TextArea FontSize not updating all text
    philippe.sabourin
      Hey guys,
      I'm trying to set the font size of a few TextArea's after the user selects the size of the text they want. However, this is only changing the last line of the textarea (and any new lines after those are entered) instead of the entire text. These TextAreas hold chat messages and are not editable. Here is what I tried first:
      public function setFontSize(size:Number):void
          chatLog.setStyle("fontSize",size);
      and then I tried this:
          if(chatLog.text.length > 0){
              var allText:TextRange = new TextRange(chatLog, false, 0, chatLog.text.length-1);
              allText.fontSize = size;
      Neither of them seemed to change the font size of anything but the last line. The example i've found online and on the adobe site have both shown this to work. I use the htmlText property to set the text. Any ideas?
      Philippe
        • 1. Re: TextArea FontSize not updating all text
          Flex harUI Adobe Employee
          If you have font and size tags in the HTML they'll override the styles.
          Alex Harui
          Flex SDK Developer
          Adobe Systems Inc.
          Blog: http://blogs.adobe.com/aharui
          • 2. Re: TextArea FontSize not updating all text
            philippe.sabourin Level 1
            The only tags I have are <a> and <u> tags. Would those break the changing of the font size?
            • 3. Re: TextArea FontSize not updating all text
              Try reading back the htmlText and see what tags its thinks are in play.  Also, if you are using flash.text.styleSheet that also overrides Flex styles
              Alex Harui
              Flex SDK Developer
              Adobe Systems Inc.
              • 4. Re: TextArea FontSize not updating all text
                So I added a trace right after the setting of the size:
                trace(chatLog.htmlText);
                The first time I change the font size, here is the output (from 10 to 12):
                <TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="10" COLOR="#CBFF70" LETTERSPACING="0" KERNING="0">(<A HREF="event:+JIM+" TARGET=""><U>+JIM+</U></A>) flo flo flo</FONT></P></TEXTFORMAT><TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="10" COLOR="#CBFF70" LETTERSPACING="0" KERNING="0">(<A HREF="event:+JIM+" TARGET=""><U>+JIM+</U></A>) I&apos;m back in sol where are you the</FONT></P></TEXTFORMAT>
                After the above, however, the second line there shows up with size 12 font, even though there it is listed with size 10.
                Then I change the font size again, and here is the second output (from 12 to 14):
                <TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="10" COLOR="#CBFF70" LETTERSPACING="0" KERNING="0">(<A HREF="event:+JIM+" TARGET=""><U>+JIM+</U></A>) flo flo flo</FONT></P></TEXTFORMAT><TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="12" COLOR="#CBFF70" LETTERSPACING="0" KERNING="0">(<A HREF="event:+JIM+" TARGET=""><U>+JIM+</U></A>) I&apos;m back in sol where are you the</FONT></P></TEXTFORMAT><TEXTFORMAT LEADING="2"><P ALIGN="LEFT"><FONT FACE="Verdana" SIZE="12" COLOR="#CBFF70" LETTERSPACING="0" KERNING="0">(<A HREF="event:floflo93" TARGET=""><U>floflo93</U></A>) standoff</FONT></P></TEXTFORMAT>
                After this, the first line shows up with size 10, the 2nd with size 12 (which is now reflected in the output), and the 3rd with size 14, which is not yet reflected.
                Note that when I add a line I do the following (essentially, that string is actually built from a few different variables, etc):
                chatLog.htmlText += "(<A HREF="event:+JIM+"><U>+JIM+</U></A>) I&apos;m back in sol where are you the" + "\n";
                I'm sorry for the HTML mess, but I was hoping this would give you the best idea of what is going on.  As far as I know, I do not use flash.text.styleSheet.
                Philippe
                • 5. Re: TextArea FontSize not updating all text
                  Can you create a test case in 20 lines of code and post it?
                  Alex Harui
                  Flex SDK Developer
                  Adobe Systems Inc.
                  • 6. Re: TextArea FontSize not updating all text
                    I've attached a flex project archive with an simple application that can reproduce the issue. All you have to do is hit "AddText" a few times, then "SwitchFont" and repeat.
                    Philippe
                    • 7. Re: TextArea FontSize not updating all text
                      Finally got around to this, but the zip file seems to be corrupted.
                      Since you are adding text, I would be suspicious of the selection range.  Another thing to try would be to reset then entire htmlText before setting the fontSize
                      Alex Harui
                      Flex SDK Developer
                      Adobe Systems Inc.
                      • 8. Re: TextArea FontSize not updating all text
                        I was able to open the zip here, not sure what's going on. Anyways, I've extracted the main file for you, and have quoted it below (attaching didnt work).
                        When you say reset, do you mean storing the entire text in a seperate variable and then setting it to the htmlText before setting the font size? I thought about trying this before but seemed silly to have to store the same text twice.
                        Philippe
                        <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
                                  <mx:Script>
                                  <![CDATA[
                                       private var size:int = 10;
                                       public function newChatMessage(user:String, message:String):void
                                            var text:String = "";
                                            text = "<u><a href='event:" + user + "'>" + user + "</a></u>";
                                            text = "("+text+") ";
                                            text += message + "<br\>";
                                            chatLog.htmlText += text;
                                       public function setFontSize():void
                                            size += 2;
                                            if(size > 14)
                                                 size = 8;
                             </mx:Script>
                             <mx:VBox width="100%" height="100%">
                                  <mx:TextArea id="chatLog" width="100%" height="100%"/>
                                  <mx:HBox>
                                       <mx:Button label="SwitchFont" click="setFontSize()"/>
                                       <mx:Button label="AddText" click="newChatMessage('testuser','chat message')"/>
                                  </mx:HBox>
                             </mx:VBox>
                        </mx:Application>
                        • 9. Re: TextArea FontSize not updating all text
                          OK, took a look at it.  The TextArea's interal TextField's HTML handling is definitely full of idiosyncracies, I think you've hit another one of them.  It takes all of your tags specifying the size.
                          If I were you, read back the html and replace the font tags, or (and this may be a better solution for chat anyway) regenerate the html based on an external log of stored strings.  You may find out later that after a lengthy chat session that as the number of lines in a TextArea gets really big (1000) it starts to pig out so you may want to virtualize what text is actually in the TextArea and handle scrolling in some other way.
                          Alex Harui
                          Flex SDK Developer
                          Adobe Systems Inc.
                          • 10. Re: TextArea FontSize not updating all text
                            Hah, found out you can't put html tag angle-brackets in the emails because they get eaten.
                            TextField takes all of your "br" tags and replaces them with "p" tags and puts a "TextFormat" tag around each one.  I have a suspicion that only the last TextFormat is affected by changing the default font size for the TextField.  Quite frankly, I'm kind of surprised it worked on any of the text because if you read back what you put in, you'll see tags specifying the size.
                            Alex Harui
                            Flex SDK Developer
                            Adobe Systems Inc.
                            • 11. Re: TextArea FontSize not updating all text
                              I'm not really sure what you're talking about with the email? I output any kind of email in the text.
                              Also, before I had + "\n" instead of + "<br/>" at the end of each message, but it was still doing the same thing. Do you still think the solution is to store the entire text seperately and reload it when the font size is changed?
                              Philippe
                              • 12. Re: TextArea FontSize not updating all text
                                Not sure what happened, but the forums at several lines of that first reply.
                                I'd either re-add all the text (which as I said, might be better performance wise once the numbers of lines gets large), or manipulate the font size tags
                                Alex Harui
                                Flex SDK Developer
                                Adobe Systems Inc.
                                • 13. Re: TextArea FontSize not updating all text
                                  Saving the text to a seperate string and replacing it every time the font is changed worked as expected.
                                  Thanks for the help,
                                  Philippe
