This content has been marked as final.
Show 1 reply
1. Re: Transitions to a button
Bill Hunt Jun 9, 2009 2:20 PM (in response to macergodt)Yes, in PrPro (or the NLE of choice), create a DV-AVI file for your Button Transition. I usually use a still shot of my Menu, and then create the AVI to go to my Timeline, again often using a very short Duration of a still image from that Timeline's first frame. Import this DV-AVI into En as an Asset. I also use elemental streams, i.e. a Video-only DV-AVI file (not muxed) and a PCM/WAV Audio-only (not muxed) for the Audio portion. One could also use a DVD-compliant AC3 Audio-only file. Note: if you have Audio on your Menu, you want the format to match between the Menu's Audio and the Button Transitions. If you use PCM/WAV for one, use it for the other. If you use AC3 for one, use it for the other.
