1 Reply Latest reply on Jun 9, 2009 5:38 PM by jendehaan
    Sometimes can't clear keyframe
    Chemistry guy Level 1
      Why is it that sometimes I can clear a keyframe and sometimes not. Not being able to clear a keyframe seems to happen when I copy and paste frames from more than one layer. The keyframe in the first layer copied can't be cleared.
        • 1. Re: Sometimes can't clear keyframe
          jendehaan Level 4
          Clear keyframe behaves a bit differently if you're trying to clear in frame 1. There needs to be a keyframe at frame 1, so it typically does not clear in the way frames at other locations do.
          Or, are you having difficulty clearing frames at other locations?  I can't reproduce anomalies after copy-pasting keyframes. If this is the case, do you have some more detailed steps I could try following or a file that demonstrates this?
          Thanks!
