0 Replies Latest reply on Jun 9, 2009 9:31 PM by GordonSmith
    [svn:fx-trunk] 7700: Integrated TLF build 450.
    GordonSmith Level 4
      Revision: 7700
      Author:   gosmith@adobe.com
      Date:     2009-06-09 21:31:13 -0700 (Tue, 09 Jun 2009)
      Log Message:
      Integrated TLF build 450. This integration required no changes to framework code.
      From TLF's ReleaseNotes.txt:
      Build 450
      • Fix bug 330941 BackgroundColor and Color export differently
      - backgroundColor now exports in 0x hex format
      Build 449
      • Eliminate IInternalFlowComposer interface
      • Fix 2328573 - remove textLine from BackgroundManager's cache when calling recreateTextLine() with recycled line.
      • Fix 2347701 SelectionManager and EditManager keyDownHandlers should call event.preventDefault() if they handle the key
      Build 448
      • Changing behavior of vertical alignment of bottom or middle when content height exceeds container height with scrolling on. Now it will act as top aligned.
      Build 447
      • Rename TextFlow.getElementById to getElementByID
      Build 446
      • Review changes - TextContainerManager
      1) setText parameter named text
      2) setTextFlow parameter named textFlow
      3) hasScrollRect should be private
      Build 445
      • Fix 2340553 Insert of "auto" sized InlineGraphics don't undo
      • Fix 2331720 TextContainerManager.getText - the parameter is a separator and is not added after the last paragraph
      • Fix the width of the paragraph terminator should not be included as part of the content width in lineBreak=explicit mode.
      • Fix cursor blinks in read-select mode, it should not blink. Now check the interactionManager's editingMode before setting the blinkRate.
      • Fix links at the end of the TextFlow don't cause the cursor to change to a hand cursor when the mouse passes over the link.Build 443
      • Fix 2297125 Vertical adjustment now adds height proportional to existing line spacing, even when lines are created using the text line factory
      • Fix 2305477 Added support for compilation of linkNormalFormat, linkActiveFormat and linkHoverFormat in mxml
      • Added an sdk example for context menu
      QE Notes: None
      Doc Notes: None
      Bugs: None
      Reviewer: None
      Modified Paths:
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/in/tlf/textLayout.swf
          flex/sdk/trunk/in/tlf/textLayout.swz
          flex/sdk/trunk/in/tlf/tlf.properties
