1 Reply Latest reply on Jun 10, 2009 2:12 AM by Richard_Abbott
    Doubt in xml?
    karthik flex
      hi
      i have an xml
      <root>
      <data>
      <time datas="Hello" second="one">08:00</time>
      <time datas="Hello1" second="two">08:00</time>
      <john>08:15 Sick Call,08:25 Lung Problem,08:30 Kidney Problem</john>
      <michel>08:15 Sick Call,</michel>
      </data>
      <data>
      <time datas="John" second="Bye">09:00</time>
      <john>09:15 Sick Call,</john>
      <michel>09:25 Lung Problem,09:15 Sick Call,09:30 Kidney Problem</michel>
      </data>
      </root>
      inside data node you can see in red two "time" node when i access this it is not displaying one below the other it is coming continuously
      it is displaying as
      HelloHello1 onetwo
      but i need as
      Hello one
      Hello1 two
      inside one cell
      any idea
      karthik.k
        • 1. Re: Doubt in xml?
          Richard_Abbott Level 3
          karthik,
          I imagine you are using this as data provider for a DataGrid? If so, it probably assumes a single tag of the indicated name within the hierarchy. To get round this, you would:
          a) Add your own renderer for the column in question
          b) in the renderer code, get all the <time> children into an XMLList (something like root.data.descendants("time"))
          c) iterate over the XMLList and add the desired new line breaks between each item
          Richard
